Using perl script within GUI to extract lines from within cif files
I'm new to Perl and am not sure whether I can do what I intend so would greatly appreciate some advice please.
Within Materials Studio (2016) GUI I want to use perl to open some cif files within a directory held outside of a  Materials Studio project, and then extract a particular line from each cif file, using this line in a subsequent calculation, also contained within the perl script.
I don't understand why the following fails at   open (my \\\$fh, '<', \\\$file2) or die \\\$!; (The following is part of a larger code)
my \\\$i = 0;
my \\\$input_suffix = 'cif';
opendir my \\\$folder, \\\$inputFilesFolder or die "Couldn't open folder";
my @allfiles = grep  /^.+\\.\\\$input_suffix\\\$/, readdir \\\$folder;
print "@allfiles";
print "This is the main folder: \\\$folder";
foreach my \\\$file (@allfiles) {
     print "Parsing \\\$file \\n";
print "This is the list of cif files:@allfiles\\n";
print "This is the number of elements in '@allfiles': " . @allfiles . "\\n";
my \\\$prefix = "\\\$folder";
#print "\\\$files[2]\\n";
my @filepaths = "\\\$outputFilesFolder/\\\$file";
# my @filepaths =  map { \\\$prefix . \\\$_ } @allfiles;
print "This is now the new list of filepaths: @filepaths";
print "Size: ",scalar @filepaths, "\\n";
print "This is each cif file with its full path:@filepaths \\n";
print "# This is the number of Elements: " . @filepaths . "\\n";
#closedir \\\$folder;
print "This is the directory we're now in: \\\$folder \\n";
foreach my \\\$file2(@filepaths) {
   print "This is each file and its path again: \\\$file \\n";
    print "# Elements: " . @filepaths . "\\n";
    my @lines = <\\\$fh>;
       for (@lines) {
    if (\\\$_ =~ /(z_value)\\s\\:\\s(\\d+\\.\\d+)/) {
        print "\\\$2\\n";
Am I trying to do the impossible within the GUI?
Advice welcome!
Many thanks and best wishes,
Dawn Geatches
Answers 1
JD
JD 2017-07-12
Hi Dawn,
No it is not impossible. Opening and reading files in Perl is pretty standard, if a little frustrating sometimes. As this question is pure Perl and not Materials Studio related, I suggest you find a good internet reference on reading directories and files, eg,
https://perlmaven.com/reading-the-content-of-a-directory
Note there could be differences that depend on the version of Perl. You can print out the version with the line "print $];"
