Unable to export data files in COSMOTherm
Hello everyone,
I am using the COSMOTherm 2024 version and facing serious issues while exporting the calculated data from the software in .xls (Excel) format. It creates an Excel file with the names and the location I am giving. But, when I return to the folder, it shows empty (0Kb).
Does any user have any solution for it? Or facing the same issue?
Thanks in advance.
Answers 1
TG
TG 2024-04-03
Thanks for writing in this community.
Sorry to read that the export doesn't show up as expected. As an immediate workaround, in case you were not aware, it is actually possible to copy the content of the result tables and paste it into your own excel spreadsheet.
Nevertheless, I'd like to take a closer look to see if the export functionality is working as it should. Therefore, could you please:
1- Run a job where this issue occurs
2- Once the job completes, make sure that you are seeing a .tab result file in the BIOVIA COSMOtherm interface
3- Try to export the file by clicking on the floppy disk symbol and then save the xls on the Desktop
4- Attach the resulting file (even if it measures 0Kb) as well as the zipped job directory (right click on Job row in the Jobs panel on the left in default display > View Job directory to access contents from the explorer) to your forum post
I made a quick try myself using simple chemical potential of 1-octanol in 1-octanol (Properties > Mixture) and I obtained a .xls file. So, I wonder if this issue might depend on the specifics of the job you are running.
Thanks in advance,
Best regards,
Théophile.
