Is there any tutorial for computing adsorption of molecules on to polymer system under periodic boundary conditions? I am trying to simulate adsorption (GCMC method) of molecules on to a PEO melt using Sorption module. I made the equilibrated melt and also created the sorbate molecule (acetone). When I tried to use the sorption module, all values are coming out to be zero. Any advice on this?
Hi @VS. Thanks for using BIOVIA products. Can I check if you're using Materials Studio Simulation on the Cloud OR Materials Studio on-premise? Thanks, Patricia
I am using MS simulation on the cloud
Hi @VS, have you looked at the Materials Studio tutorials? There are >120 of them under Help | Tutorials including two on sorption, describing how to use it with zeolites. However, what little you describe seems more like a case for either adsorption locator (to identify adsorption sites) or amorphous cell. Have a look at the tutorials to see how they map onto your problem. You may also want to check out the tutorial Forcite Plus | polymer Interactions with a metal oxide surface for inspiration.
Perhaps there is simply not enough free volume to put in an Acetone molecule or you may need by far more loading steps.
Could you please zip .xsd file which you use as input and add the resulting .zip file to the post.
In the Materials Studio help there is a tutorial "Predicting the loading of CH4 in zeolite MFI with Sorption"
Hi @VS
I wanted to make you aware that you can always create a support ticket so our customer success team looks into your specific problem and provides alternatives. BIOVIA support is not only about reporting defects, it's also about help you make the most of BIOVIA applications.
Regards, Patricia
@FH Yes, I did try the tutorials. I was wondering if it is due to PBC in the polymer system (adsorbent) that acetone is not adsorbing. I am surprised that a small molecule such as acetone cannot adsorb on to this system. When I tried with Methane, it was adsorbing (the example case is also with methane). So, I was wondering that if there are more than one C atoms or anything other than methane, does the system work?
@CM Yes, I shall share the inputs and outputs here.
@CM Please find the files attached for Methane (works) and for Acetone (doesn't work). I tried with a much larger number of steps and still it is not working for Acetone. I am surprised since Acetone has a size very comparable to methane.
I checked with propane and polyurea (1 monomer). Polyurea is almost same as acetone except for NH2 at the end instead of CH3. Similarly, propane and acetone has three CH2 monomers. I generate an acetone molecule by drawing the molecule. I was wondering whether I am overlooking (like assigning forcefields etc) while I just draw the molecule. Any help would be greatly appreciated. I am attaching the files for Propane and Urea as well here.
I figured that if I use a density of 1 g/cc (after geometry optimization), molecules are getting adsorbed. But if I run a MD simulation and equilibrate to its actual density (1.09 g/cc) nothing is getting adsorbed. I am surprised that a very small change in density (and a small change in box size - from 28.3 to 27.6 Angstrom) is not allowing the molecule to get adsorbed. Am I doing something wrong here
Hello. Sorption assumes a fixed matrix - like zeolites. The Tg of PEO is -50oC so if you're intent is to model the sorption coefficient at room temperature, using the sorption module won't reflect the real system.
In polymers, the transport properties of molecules larger than small gases are highly dependent of the of the polymer chains movements That's not captured in the sorption model because it was designed for study of penetrants in Zeolites.
Maybe we could provide alternatives if you'd share what's the goal of the modeling project you're working on.
Regards, Patricia
@Patricia GESTOSO Thank you for the message. 1)I am trying to model the isoteric heats of adsorption of small molecules onto polymer matrices. This is mainly to understand how small molecules interact with polymer matrices for gas sensor modeling. Basically, I am trying to look at the adsorption efficacy of different small molecules onto polymer matrices. Therefore, I am looking for a GCMC type of simulation to understand the adsorption efficiency (free energy of adsorption). 2) I am simulating at 298 K which is above the Tg of polymers. I agree that the polymer movement would be minimal. Could you please let me know why the isoteric heat output from SORPTION module is not good for this? Could you also provide an alternative.
I also have one more question. When I tried to do the Fixed loading in SORPTION module for different small molecules on PEO matrix, the electrostatic energy is constantly zero. Why is that so? The VdW and intramolecular do change, but the electrostatic is constantly zero irrespective of the force field used. I can provide more data if needed. Thank you in advance.
Hi @VS,
Based on your questions and project goals, my advice is to open a service request ticket where people like Carsten and myself can fully support you. Our support team is made up of professionals with M.Sc., Ph.D. and post-doctoral studies in domains such as computational physics and chemistry so they can deliver both scientific and technical support.
As a reminder, this community is public and the aim is for users to help each other. Typically, it’s more effective for requests that have a very narrow scope.
Regards, Patricia
https://www.3ds.com/support
