I am running some simulations of polymers with drug molecules in water in Materials Studio using Discover module. I am having serious problems using thermostats/barostats in MD calculations as noted below.
I know that Berendsen thermostats and barostats are good to use during equilibration and Nose Hoover thermostat + Parrinello Rahman barostat are good for production. However, even after a long equilibration (~5ns) on a small system (~3nm box size), the system does not reach the reference temperature of 298 K if I use the Nose Hoover+Parrinello Rahman. Below is a fragment of the output for production. I understand why the pressure fluctuations are large for small system (my reference pressure is 0.0001 GPa=1bar) but the temperature should go to 298K. If I use Berendsen thermostats and barostats for production as well, the density values keep falling and go less than 1 g/cc, Nose Hoover+Parrinello Rahman seem to give reasonable density values for my system. Any inputs on why is this happening?
Regards,
Prateek
(This is the first post in the forum so please let me know if I am adhering to any forum rules)
MOLECULAR DYNAMICS
__________________
Ensemble : NPT
Temperature : 298.00 K
Control Method : Nose, Q = 18443577.60 kcal/mol*fs^2
Pressure : 0.0000 GPa
Stress : Sxx = -0.0001 GPa Syy = -0.0001 GPa Szz = -0.0001 GPa
: Syz = 0.0000 GPa Sxz = 0.0000 GPa Sxy = 0.0000 GPa
Control Method : Parrinello, cell mass = 20.00 a.m.u.
Timestep : 1.00 fs
Duration :3000000.00 fs
Integration Method : Velocity Verlet
Initial Velocities : Random Velocities from Boltzmann distribution
Initial Temp. : 298.00 K
Dynamics Summary
________________
Initial Final Average Std. Dev.
Tot. energy (kcal/mol) -747.765 -737.965 -914.051 94.996
Pot. energy (kcal/mol) -2383.205 -2266.891 -2424.024 84.996
Kin. energy (kcal/mol) 1635.440 1528.927 1509.973 37.018
Temperature (K) 298.000 278.592 275.138 6.745
Pressure (GPa) -0.031331 -0.013400 -0.031288 0.149142
Volume (A^3) 19449.049 18957.028 18677.540 194.104
Density (gm/cm^3) 1.1347 1.1642 1.1817 0.0123
Time used by 3000000 steps is 34 hours 27 mins 25.28 secs (0.041 secs per step)
