TG script issue
Good afternoon everyone, I have encountered an issue with the Glass Transition Temperature (TG) script. Whenever I use COMPASS to calculate, it will report an error message indicating excessive energy and non physical steps. I don't know how to improve my script to avoid this problem. This compressed file contains my script and the object I want to run. I hope someone can help me. Thank you!
Answers 2
RA
RA 2025-06-03 Best Answer
Your nanocluster has composition Ni13O6, whereas COMPASS expects a stoichiometry of 1:1. This is causing the system to have a net charge. You will see a warning in the text report:
Warning: The system has a net charge of 11.2 e.
The chosen summation method will add a uniform background charge of -11.2 e to neutralize.
Note for metal oxides it is recommended to delete bonds after assigning forcefield types. This avoids missing parameters which you also find in the text report:
Energy contributors with missing parameters:
  Bond Stretch                : (ni2o o_m)
  Angle Bend                  : (ni2o o_m ni2o), (o_m ni2o o_m)
  Torsion                     : (ni2o o_m ni2o o_m)
You can set the energy penalty using the EnergyDeviation parameter, but I would first make the clusters charge neutral. Bear in mind that COMPASS parameters are for NiO crystal; they may not work well for surfaces.
BC
BC 2025-05-30
How to increase the upper limit of energy limitation? Thank you all!
