Hi everyone;
As you may know, we can easily calculate the solubility parameter and the cohesive energy using Forcite module in the molecular scale, but, is there a way to calculate it from a mesoscale system?
Thank you
JARRAY
Hi everyone;
Thank you
JARRAY
Hi Jarray,
The cohesive energy is equal to minus the intermolecular energy, i.e. the intramolecular energy minus the total energy. Divided by the volume will give you the cohesive energy density, the square root of which is the solubility parameter.
In principle you can do this on the mesoscale in the same way, but I suspect the result may not be as accurate as (1) the force fields are generally not parametrized to match cohesive energy (2) the intra-mesomolecule energy in the condensed state may differ from the gas phase, as effectively it is a free energy.
Still it would be interesting to see the results if you have any.
Best,
Reinier
