Saving a Learn PCA Model through a Pipeline Pilot Protocol in Materials Studio
Hi Everyone,
I am trying to use Pipeline Pilot to a protocol that produces a Learned PCA model. I am using the Destination Folder as \\\$(Jobdir) with the LearnedModelName as Test. When running the the PCA pipeline in Materials Studio I get the following error:
Protocol failed:
Cannot access component named job:/16D3370F-F468-1145-B8DD-CD6ECB864F86/Test
I can write study tables via this syntax so it confuses me why it doesn't hold true for a Learn component.
Any help would be greatly appreciated,
P
Answers 2
TK
TK 2023-03-21
What is the behavior if I change the value of Destination Folder as follows?
Before : $(Jobdir)
After: $(Username)/Learned PCA Models
K.
PG
PG 2023-03-30
Hi @PH,
There is a misconception on the approach. The PCA component allows saving your model into your user area. That area correspond to its location under the XMLDB and not under the jobs folder. The XMLDB is the database were Pipeline Pilot save Protocols and Components.
I have added three screenshots reflecting where the component will end up depending on how you configure the component (User Area, Components, Protocols)
From the Learn PCA Model the documentation indicates that the protocol will be saved as component on your user tab.
"This analysis is saved as a learned model in the Learned PCA Models folder of the user tab. This can later be used as a component."
But you can adapt it to expand its usage as part of the Protocols or Components Tab.
Hope that helps to clarify the scenario.
comment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment image
