Running with 2 MPI processes. There are 2 MPI processes running on the same node as the root process. This binary does not support OpenMP threading
Dear All
I have recently updated Materials studio 2016 to my windows machine. We have a licence for CASTEP and ONETEP as well.  It works absolutely ok with CASTEP using single core along with parallel calculations but with ONETEP, It does not work  for even a single machine.   Please update me what to do. here i have copied the warning .............
Thanks
Faruq
Job started: 27-04-2016 10:41 (+0100)
License checkout of MS_onetep successful
Reading parameters from file "Al.dat" ...... done
Checking processes and threads...
   This binary does not support OpenMP threading.
... done
ONETEP terminated abnormally due to the following error:
Error in parallel_strategy_list_overlaps: spheres exceed cell size.
... detected on MPI rank #0.
ONETEP execution aborted
Checked out license feature: MS_onetep [for 4804:219863:2:THE UNIVERSITY OF BOLTON] (1 copy)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
Answers 1
VM
VM 2016-04-28 Best Answer
The error is described in the lines that say "error". OpenMP is a warning.
The error comes from ONETEP's dislike of small cells. If atom-centered spheres overalp with their periodic images, ONETEP cannot operate. This code is designed for large systems; in fact, the crossover in terms of performance between ONETEP (linear scaling) and CASTEP (quadratic to cubic scaling) happens for systems with hundreds of atoms. Smaller systems are faster with CASTEP. Anyway, if you want to use ONETEP, please make a bigger supercell - look at atomic radii in ONETEP setup options to get an idea of how big it should e to avoid spheres overlap.
Cheers
