regarding modification of H-bonds
Hi
Is it possible to modify H-bonds in a crystal structure keeping the lattice parameters same/ similar.
Rgds
Answers 2
BM
BM 2014-12-10
Hi
You have some control over the algorithm. Click on the help button on the hbond dialog for details.In summary,  you can change the elements that can be considered donors or acceptors. You can also change the cutoff in terms of distance and the angle between the donor, acceptor and hydrogen.
Note that this has no effect on any Forcite calculation.
Regards
Simon
JD
JD 2014-12-11
Hi Simon
I have powder solved one pxrd data(expt.) of a crystal str. and then tried to match it with the predicted ones as follows-
Lattice parameters-
Pedicted best match-
a=26.607247, b=7.019383, c=11.513122 & beta=97.76649, crys. density= 1.42316
powder solve crys. str solution-
a= 26.629629, b=9.065169, c=12.019799 & beta=99.30071, cyrs. density= 1.05890
Space gp. = C2/c (both strs.)
But I found that their H- bonding is not matching. So can I consider it as  best match or else what should Ido? I tried to powder solve with other  space groups too but didnt get get to fully match parameters with predicted one. Then what conclusion should i draw?
regards
