Hello Everyone,
First thanks for your attention on this question.
I built a mixture in Amorphous cell, with 50 A molecules (CxHyOz) and 50 B molecules (CxHyNz).
My question is, if I would like to calculate RDF between A and B, what should I do?
My current method is to select all A molecules as Set 1, and select all B molecules as Set 2, then using Forcite-RDF module. Is it correct, and this RDF is atoms-atoms RDF or centroid-centroid RDF? do I have to creat a centroid any more?
By the way, If I want to study A-A interaction/structure, when I choose set 1 and set 1 in Sets, do I have to check "Include intra-intermolecular components"?
Thanks in advance,
best,
Guangji
Thanks in advance,
best,
Guangji
Which RDF is calculated depends on the type of objects in the sets. If both sets contain centroids, Forcite will return the centroid-centroid RDF. If both sets contain atoms (and no centroids), it will be the atom-atom RDF. To find out which objects are in a set, use the Properties Explorer.
If two different sets are selected (e.g. A and B), Forcite will return 3 RDFs: for AA, BB and AB. The AB curve will show the distribution of distances between atoms/centroids on A molecules and atoms/centroids on B molecules. Since they are on different molecules, there is no intramolecular contribution, and the option "Include intra-intermolecular components" is irrelevant (it is not available for centroids).
To automatically create a set of centroids you can use the Find Pattern tool. See the topic "Finding patterns" in the Help.
Regards,
Reinier
Thanks for your kind reply.
May I ask a further question?
Following your instruction, and if two different sets are selected (e.g. A and B), Forcite will return 3 RDFs: for AA, BB and AB. Then What does AA (or BB) mean?
If I choose the same sets, (e.g. A and A), thee will be also 3 RDFs, "total. inter and intra"... So is there any difference between "total" here compared with "AA" above?
Thanks in advance,
Best,
Guangji
