Hello Everyone,
I built a Mesostructure Template containing two formers.I have created a tube former and packed it with fixed beads.The tube former encloses a rod former.Polymer chains are packed in the rod former.
To run a Mesocite DPD task,
When the bead types in tube and rod are different,how do we define the length scale and mass scale on Build Mesostructure tab? Could anyone help me out?
Thank you,
Deepa
Thank you,
Deepa
How do we specify a length scale and mass scale which is common for two different bead types?
Hoping to get some help.
The mass and radius of each bead type is accessible via the Bead Types dialog on the Mesostructure toolbar.
But the radius is not the same as the length scale. It is only used for constructing mesomolecules to identify the appropriate bead connector length. Of course in DPD, there is a single length scale and all beads have the same size by default (unless you edit the parameters in the DPD forcefield).
