Currently, I am learning confined shear task. I saw that in the manual, it says "during the shear process, the wall atoms are allowed to fluctuate about (moving) equilibrium positions, to which they are attached by harmonic springs". I'm curious of it and I would like to ask how to do it through script in Materials Studio. Would be really appreciate it if anyone can give me some ideas.
Thanks,
Dear Steven,
For your information, it is possible to run a Confined Shear job from a MaterialsScript. The way to do this is documented in the BIOVIA Materials Studio help, under:
Scripting in Materials Studio > MaterialsScript Application Programming Interface (API) > Modules > Forcite > ConfinedShear > Run
In particular, an example script is provided, assuming you can input a document called Layer.xsd:
________________
my $results = Modules->Forcite->ConfinedShear->Run($doc,
Settings(ConfinedShearWallVelocity => 2));
my $trajectoryDoc = $results->Trajectory;
Modules->Forcite->Analysis->VelocityProfile($trajectoryDoc);
_________________
Hope this helps,
Best regards,
Théophile.
What do you mean with this:
* The shear task.
* or the harmonic springs
What (properties) are you after at the end and what do you want to do with that?
