QSAR DMol3 Method
I'm using the QSAR module to calculate Total energy (DMol3 Periodic descriptor) for MOFs in a Study Table. How do I know what method and parameters is the software using? Any help is highly appreciated. Thanks!
Answers 1
FH
FH 2020-04-30 Best Answer
Hi, you can verify and chose the parameters when you double-click on the models highlighted in the QSAR dialog. This opens the QSAR | Models | DMol3 dialog, which provides a reasonable set of options for these calculations (such as task type, quality, solvent, functional, charge, multiplicity) that should be reasonably descriptive. The meaning of these options are the same as in the main DMol3 calculation, and any other defaults are also the same as in the DMol3 module.
