Processing output after errors in a script
Hi, All,
I am trying to generate DMol3 forces in a script, but have problems that I hope the community can help with. This is not straight-forward since there's no 'gradient' task, so I set up a geometry optimization and tell it to do 1 iteration. Then i run Dmol3 and look for any errors like this:
\\\$dmol3->ChangeSettings([ Quality => "Medium",
                           PopulationAnalysis => "Yes",
                           UseSymmetry => "No",
                           EnergyConvergence => "1.0",
                           ForceConvergence => "1.0",
                           DisplacementConvergence => "1.0",
                           Iterations => "1",
eval {\\\$output = \\\$dmol3->GeometryOptimization->Run(\\\$tempdoc);};
if (\\\$@) {
   # Something bad has happened,
   # Report error and move on to the next one
   print \\\$@;
   # do something here to process \\\$output...
} else {
    #DMol3 completed ok.
   # iterate over all atoms and grab the forces
DMol3 stops with an error that geometry optimization did not converge (as expected). On Windows, this does not generate an error. The script processes through the non-error branch. On Linux - where i really want to run - this generates an error. It goes into the error handling part of the script, but i cannot process any outputs. if I try to processes the object \\\$output I get an error that this is a null object. If I try explicitly to open the outmol file I get an error about a null file. That's particularly puzzling since i can look on the server and see the outmol file.
Do you have suggestions about how to compute gradients with a script or how to process outmol files after an error on linuix?
thanks,
george
