Problem with Van der Waals dispersion forces δd of Water
Hi everyone;
I'm traying to calculate the Hildebrand dispersion and polar solubility parameters of water (δ²=δd²+δp²) using forcite module, however, I always obtain a negative value (appear blank in the result table).
I used a cell containing 100 water molecules, with a density of 0.997g/cm3, and Ewald summation, the simulation was done in the NVT ensemble with 1000ps. the following table summarizes the results that I obtained:
Dreiding
CompassII
TIP3P
SPC/E
F3C
PCFF
Water (exp)*
charge   equilibration
Qeq
Qeq
Focrefield assigned
Focrefield assigned
Focrefield assigned
Focrefield assigned
Focrefield assigned
Solubility parameter
δ
δd
δ
δd
δ
δd
δ
δd
δ
δd
δ
δd
δ
δd
δ
δd
(J/cm^3)^0.5
50.94
n/a
37.2
n/a
47.7
n/a
50.2
60.3
55.7
n/a
81.2
n/a
47.2
7.2
47.9
12.9
As you can see, no forcefield/model gives a good value of the dispersive solubility parameter, I also tried equilibrating in the NPT ensemble, and a simulation with higher time 9000ps, but δd is always n/a and the Van der Waals cohesive energy is always positive.
I don't understand why,  any explanation/advice/suggestions/solution?
Thank you in advance!
JARRAY
*Barton A.F.M.Handbook of solubility and other cohesion parameters- 2nd ed. 1991.
