Problem with Forcite
This looks a computer-dependent problem for me. Forcite Module of MS4.3 stopped right after it is getting started. The log file looks like this:
Perl lib version (v5.8.7) doesn't match executable version (v5.8.8) at C:/PROGRA~1/Accelrys/MATERI~1.3/etc/Gateway/perl/lib/Config.pm line 46. Compilation failed in require at C:/PROGRA~1/Accelrys/MATERI~1.3/etc/Gateway/perl/lib/DynaLoader.pm line 25. BEGIN failed--compilation aborted at C:/PROGRA~1/Accelrys/MATERI~1.3/etc/Gateway/perl/lib/DynaLoader.pm line 25. Compilation failed in require at C:/PROGRA~1/Accelrys/MATERI~1.3/etc/Gateway/../../bin/perl/lib/Cfx/COM.pm line 13. BEGIN failed--compilation aborted at C:/PROGRA~1/Accelrys/MATERI~1.3/etc/Gateway/../../bin/perl/lib/Cfx/COM.pm line 13. Compilation failed in require at C:/PROGRA~1/Accelrys/MATERI~1.3/etc/Gateway/../../bin/perl/lib/Cfx/COM/Variant.pm line 4. Compilation failed in require at C:/PROGRA~1/Accelrys/MATERI~1.3/etc/Gateway/../../share/Resources/MatServer/Perl/lib/MatServer.pm line 24. BEGIN failed--compilation aborted at C:/PROGRA~1/Accelrys/MATERI~1.3/etc/Gateway/../../share/Resources/MatServer/Perl/lib/MatServer.pm line 24. Compilation failed in require at -e line 7. BEGIN failed--compilation aborted at -e line 7.
However, as I checked the perl coming with MS4.3 is 5.8.7 although my computer does have perl 5.8.8.
The perlrunner.bat is as follows:
@echo off
set DSD_ROOT=C:\\PROGRA~1\\Accelrys\\MATERI~1.3\\etc\\Gateway\\root_default\\dsd
set DSD_JOBSROOT=C:\\DOCUME~1\\ALLUSE~1\\APPLIC~1\\Accelrys\\MATERI~1\\4.3\\Gateway\\root_default\\dsd
set CFG_ROOT=C:\\DOCUME~1\\ALLUSE~1\\APPLIC~1\\Accelrys\\MATERI~1\\4.3\\Gateway\\configurations\\default
C:\\PROGRA~1\\Accelrys\\MATERI~1.3\\etc\\Gateway\\perl\\bin\\perl.exe -IC:\\PROGRA~1\\Accelrys\\MATERI~1.3\\etc\\Gateway\\perl\\lib -IC:\\PROGRA~1\\Accelrys\\MATERI~1.3\\etc\\Gateway\\perl\\site\\lib -IC:\\PROGRA~1\\Accelrys\\MATERI~1.3\\etc\\Gateway\\root_default\\dsd\\commands C:\\DOCUME~1\\ALLUSE~1\\APPLIC~1\\Accelrys\\MATERI~1\\4.3\\Gateway/root_default/dsd/servers/MatServer.pl
So, it only looks for the perl coming with MS4.3.
Any clues?
Thanks in advance.
Charles
