Hi
I recently using Focite Module to do molecular dynamics. The SiO2 substrute is used. COMPASS force field is choosen. But after geometry optimisty, the problem is written in the log file.
Energy contributors with missing parameters:
Inversion : (o si4z si4z si4z), (si o o2z o2z), (si o2z o2z o),
: (si o2z o2z o2z), (si4z o o2z o2z), (si4z o2z o2z o),
: (si4z o2z o2z o2z)
Energy contributors using automatic parameters:
Bond Stretch : (o si), (o si4z), (o2z si)
Angle Bend : (o si o2z), (o si4z o), (o si4z o2z), (o2z si o2z),
: (si o2z si), (si o2z si4z), (si4z o si4z)
Torsion : (si o2z si o), (si4z o2z si o), (si o2z si o2z),
: (si4z o2z si o2z), (si4z o si4z o2z)
So which kind of forcefield can be used in my study?
Thank you
Best regards
Thank you
Best regards
The energy contributors with missing or automatic parameters all contain the type o ("oxygen, generic"). This could mean a problem with the structure rather than the force field.
For instance, if you cleave SiO2 you will end up with unsaturated oxygen atoms on the cleave plane. These would carry a charge and will normally be saturated, e.g. by hydrogen.
To see if your structure is unsaturated, apply the "Adjust Hydrogen" tool. You may find after this there are no more missing parameters.
Best,
Reinier
