Dear sir:
Several times after I finished the MD job (with Forcite), the results send back from the server and I got the ~.xtd file and others. But then the animation tool shows no function!(no any frame) The same situation occurs when I try to copy the results file directly from the server, or try to open the .trj (only one frame in the model window). If anyone can provide me some methods to regenarate/estasblish the correct .xtd or .trj? Or it's the software limitation?(the .trj file is about 2-3G)
Thanks
Wolfgane
Dear Wolfgane,
Hmm, that is a mystery. For a standard Forcite run, it creates an XTD file which is basically an XML wrapper for the frame coordinates which are stored in the binary TRJ. Check first the obvious, that you are supposed to have more than one frame in the output (i.e. check the "Frame output every" parameter). in your case, since the TRJ is so large, I am assuming that is not the problem.
Perhaps you can do a very small run, so that you can easily upload the files to the forum and we can have a look at them. For example I have attached a short singe water molecule trajectory. Are you able to view this trajectory?
Best,
/Jason
Dear Jason:
Thank you for tour kindly replay. Actually, this problem occurs only in my recent huge MD job and not always but sometimes. I believed that will correlated with the big .xtd (file size ~200-300MB). In my small case job that didn't happen. These day I try to use Trj2Ascill to transfer the .trj, it works but the result is too big to handle in windows ( txt file over 9GB, I can only check the head part and it seem good). But after I transfer this txt back to trj with Ascll2Trj, it remains no Frame. Anyway, I'll continued to try to solve it. If you have some new idea, please talk to me.
PS, does the Accelrys try to re-coordinate the MS to 64bit version? In some huge results/continued jobs the X86 version will meet the memory locate error problem.
Regards
Wolfgane Lan
What version of MS is it?
Now I used the MS 5.0 versions.
wolfgane
Thanks, I know there is some internal discussion going on about this, so stay tuned.
Dear Wolfgane,
In version 5.0 of Materials Studio, we found an issue relating to download of trajectory files that were larger than 4Gb. In the latest version, we have fixed this issue and I can confirm the following.
In Materials Studio 5.5 we can:
We still have a limitation in Materials Studio 5.5 in that you cannot upload files larger than 4Gb to the server. For example, this means that you cannot restart a Forcite Dynamics calculation on a trj larger than 4Gb as the trajectory will not be transferred over to the server correctly.
Regards,
Stephen
Thanks, Stephen. I've upgrade to MS 5.5 and it works OK for the old big .xtd file.
YK Lan
