probability distribution of end-end distance
Dear all,
Can anyone help me with the script file, for obtaining a plot of the probability distribution of end to end distance of a polymer chain?
Thanks and regards,
Deepa
Answers 7
JD
JD 2016-02-05 Best Answer
Okay, well first of all, I recommend NOT building a chain with 500 monomers!
But if you must, here is a trick to work around the problem:
  • Select the first methylene and move it near the other end of the chain (SHIFT-middle button). You will get a very stretched C-C bond.
  • Now create your distance measurement
  • Move the methylene back near where it was.
  • Select the first two methylene groups and click the Clean button
JD
JD 2015-09-08
Hi Deepa,
You don't need a script for that. You just need to create a distance measurement on each polymer (can be automated using pattern search) and then run the Forcite | Analysis | Length distribution tool.
Best,
Jason
DM
DM 2015-09-08
Hi Jason,
Thank you so much.That saved a lot of my time.
Regards,
Deepa
DM
DM 2016-02-03
Hi Jason,
Is it possible to create a distance measurement for a polyethylene chain which has 500 monomers?
I am not able to manually select the terminal Head and Tail atoms using the distance measurement tool.When I zoom in, the terminal ends go out of the vicinity since the chain length is quite long.
I would like to know if there is any way to select the terminal atoms and measure the end to end distance.
Thank you
DM
DM 2016-02-05
Hi Jason,
Thanks for the wondeful suggestion.It works!
I am trying to calculate the structural properties of a single chain .The idea is to increase the number of monomers and check whether the simualtion results are in agreement with the predictions from Scaling laws.Since the Scaling relations are valid when the number of monomers are large,I have chosen 500 monomers.
Could you please explain  why building  a chain with 500 monomers is not recommended?
Looking forward to your response.
JD
JD 2016-02-06
Because with such a large chain it takes a lot longer to sample the config space, so you never really know if you have enough data. Whereas with shorter chains you can sample them more exhaustively within a reasonable period.
Moreover, I would expect a flexible chain like polyethylene to converge to the scaling laws at much lower chain lengths. The standard thing to do is extrapolate to zero on a Rg vs 1/N plot to find the infinite chain length answer.
DM
DM 2016-02-07
Hi Jason,
I tried with shorter chain length.The end to end distance value of the shorter chain is greater than the value of the longer chain(which contradicts the predictions from scaling laws).
Does it has something to do with the periodic boundary conditions that I use?
