After geometry optimization for twice in polymer use Forcite Module,then calculation use Forcite Dynamics(choose NVE),come forth an following error :
Dynamics calculation - Deviation in total energy (2.54709e+006 kcal/mol) between successive steps was greater than the specified maximum (50000 kcal/mol).
Could you tell me how to solve this question? Thank you very much.(I'm sorry ,my english isn't good.)
rms force : 4.927E+000 kcal/mol/A
max force : 1.073E+001 kcal/mol/A
To find out where the forces are in the system, use Tools > Vectors, choose Object type = Atom and Property = Force.
It sometimes helps to optimize with a simple forcefield like Dreiding first, and then continue with the forcefield of choice. It is important that you use the same settings (forcefield, summation methods, charges, etc) in Dynamics as you used in Geometry Optimization.
Have a look through the dynamics text report to see if there are any missing terms (e.g. due to wrong chemistry of the model).
If all looks fine you could run dynamics with a smaller time step (e.g. 0.1 fs).
For very large systems you could try increasing the energy deviation tolerance (Advanced tab of the Forcite Dynamics dialog), although the error usually indicates something is wrong with the structure.
If all fails, attach the structure to this post so people can have a look.
I have faced a similar problem, and non-off the mentioned solutions work on my system!
Is there any other suggestion?
I suggest posting a new topic, stating the steps you took and the problem observed, if possible with the job folder or structure attached.
Thanks,
Reinier
