Polymer in Sodium Chloride Solution
Hello Community,
I want to find the diffusion coefficient of sodium chloride solution in which a polymer has been soaked. Please may I know how do I go about modeling the sodium chloride solution?
Thank you.
Ang
Answers 2
JL
JL 2024-03-29
Hi Ang,
I’m afraid you’ve touched on a long-standing challenge in modeling polymer properties, diffusion coefficients in your case.  It's established that it'll be extremely computationally challenging to model polymers (mixture in your case) of realistic molecular weight, as adequate sampling of intra-/inter- chain interactions grows exponentially as the modeled molecular weight of individual polymer chains increases.  Typically, one will need to use an extrapolation method, starting from monomer, up to a reasonable sized oligomer, and compute the same property, and later on extrapolate to the desired molecular weight.  Please refer to the following seminal paper in the regard:
Cohesive properties of Ultem and related molecules from simulations
https://www.researchgate.net/publication/229406430_Cohesive_properties_of_Ultem_and_related_molecules_from_simulations
Hope it helps,
Jian-jie
RA
RA 2024-03-31
You can build the initial structure using Amorphous Cell. Start by building the individual components: Na+, Cl-, solvent, polymer. Then select them on the dialog in the ratio you want. Run Forcite dynamics with PPPM or Ewald summation. Finally analyse the trajectory for the mean-square displacement of the component of interest.
