Is it possible to change the job settings to allow running simulations on multiple cores inthe middle of a job. Just realised I have been under using a supercomputer by choosing run parallel on 1 of 36cores. Now I have a job running for several days that I can’t afford to end inthe middle. But I realise I could use more cores.
This will depend on the module and the task. For Forcite Dynamics, for example, you can stop the job and restart from the trajectory file using a different number of cores (or even a different gateway). Make sure to check "Append to current trajectory", to obtain the full trajectory.
