Dear All,
I would like to know if it is essential to check the optimize cell option in geometry optimization(for a periodic system) step?
By default the optimize cell option is unchecked.
Hoping to get some help
In which results/properties are you interested?
About which kind of system are we talking?
For classical forcefield methods can be a check how good your forcefield performs for that compound if the input is an experimental crystal structure.
I am trying to estimate the structural properties of a polyethylene chain using Forcite module, Dreiding Forcefield.
Many thanks for your response
This is quite vague.
Is it really just one chain or did you build an amorphous PE cell?
Please see the attached document.
Thanks for your time and consideration.
If it was intended to build a PE system far from the equilibrium you will get after an NVT, NPT MD sequence I would not optimize the cell in this case.
One can perhaps even unbuild the cell then and work without periodic boundary conditions.
I have done the following:
Step 1: Amorphous cell construction
Step 2: Geometry optimization using Forcite task
Step 3: NVT equilibration
In this case, is it required to check the optimize cell option in Forcite Geometry Optimization tab?
Without the periodic boundary condition, the chain coils.Also, the value of Rg obtained from simulation is smaller than the value calculated using scaling laws.
When the Optimize cell option is checked, the density of the cell decreases below the desired cell density.
Could someone explain what actually happens when the optimize cell option is selected in the geometry optimization step?
Regards,
Deepa
It is best to run initial optimization and equilibration with fixed cell parameters (i.e. without Optimize cell selected). This is because initially the forces are usually high, and the optimizer may try to expand or skew the cell to reduce the forces, which can lead to evaporation. By optimizing just the atom positions the optimizer will reduce internal stress without impacting the cell shape.
After NVT equilibration you can run NPT dynamics to adjust the cell dimensions more controllably to the external pressure.
Can I use the Amorphous Cell module to build the cell(with geometry optimization unchecked)?
I carry out geometry optimization step in the Forcite module after Amorphous Cell construction.Is it required to do geometry optimization in the Amorphous Cell construction as well?
