NPT simulation with fix position
Dear all,
I build two layers consist of Si and polymer(PS) and I want to study the dynamics of PS, during the forcite geometry optimization and NPT dynamics, the Si layer deformed. So I fix the position of some of the bottom Si-layer during optimization and NVT dynamics until equilibrium, Si-layer doesn't deform but the pressure(6.5GPa) is much too higher than normal pressure and total energy(93148.008kcal/mol) is high. As you kown, NPT dynamics can't be carried out with fix position in MS, what should I do to decrease total pressure without Si-layer deforming or does the hingh pressure and total energy affect my simulation results?
Thanks,
Lulu
Answers 5
CM
CM 2017-07-31
The only idea I have is to manually change and adjust the c-axis (assuming the the layers are perpendicular to the c-axis).
Which Materials Studio version do you use?
Which forcefield do you use?
Could you please zip and post the system before it was minimized, after it was minimized, and after the NPT?
Do you know from experiment how your Si surface really terminates?
JD
JD 2017-07-31
And how was the Si layer created? Is it really SiO2? What forcefield is this?
If you are comfortable with the surface model, I wouldn't worry so much about the high pressure. The polymer's pressure is probably more normal.
LZ
LZ 2017-08-01
Dear Carsten,
Thanks for your reply. I'm using COMPASS2 forcefield in the forcite module in MS8.0. Firstly, I built supercell Si from the imported Si.msi document. Then I took out its periodicity and executed geometry optimization, the Si structure deformed and I attached the picture. So, during my geometry optimization and simulation, I kept the position of some bottom Si atoms fixed.
comment imagecomment image
LZ
LZ 2017-08-01
Dear Jason,
Thanks for your reply. I built supercell Si, then I used amorphous cell tool to build PS cell, the PS cell pressure was normal after geometry optimization, after building layers with Si supercell, the whole pressure was so high. I want to know if it will affect the simulation results.
Lulu
CM
CM 2017-08-01
Could you please post the *.xsd files withe the Si systems?
