NPT simulation problem with fix position!!
Hi everyone,
I have a simulation cell, containing CNT and polymer. I fixed the positions of CNT atoms and then i tried to apply a NPT dynamic simulation. but I faced the following error:
Dynamics can't apply a barostat with fixed particles.
Removing all particle constraints may allow the barostat to be used
Now, I need some helps. How can we run a NPT dynamic simulation on a system in which some particles are fixed in it? isn't that possible? I know this is a common procedure in MD simulations!
Thanks,
Karan
Answers 5
CM
CM 2017-05-31
Forcite does indeed not allow to fix atom positions for NPT runs.
Why do you want to fix the positions?
AS
AS 2017-05-31
Dear Carsten,
Thank you for your reply.
I want to conduct pull-out test of CNT from polymer (epoxy). I need to run cross-linking procedure of epoxy and resin in the presence of CNT. on the other hand, I need to keep CNT's orientation in for example z-axis.
Here is the procedure:
create simulation box
put CNT in the middle of the box in z-axis orientation
pack resin and hardener with specified density in to box
run cross-linking procedure containing several NPT, NVT and annealing procedures
in the final stage I need the CNT to be in z-axis direction
Thanks,
karan
CM
CM 2017-06-01
I do not have a good idea here. The only idea I have so far (perhaps someone else has a better idea):
Do the build with NPT and without fixing the CNT.
After that do the build with fixing the CNT but NVT only at the average density you got from the first run.
Ideally perhaps even for the configuration for which the NPT run was done.
If you do NVT first for just a few steps (2-3) it is perhaps possible to reuse the velocities for the new run to make it as similar as possible. Just an idea I have.
To get a statistic one quite likely has to do more runs.
AS
AS 2017-06-02
Thank you again for your answer
well the first NPT simulation will change the CNT orientation for sure.
By the way, is it possible to make CNT a rigid body (geometry optimization) before packing polymers and then conduct NPT, NVT and so on?
CM
CM 2017-06-02
Geometry optimizations with rigid bodies are possible but not molecular dynamics.
