Dear all,
I've never used materials studio and I want to do molecular dynamics of a few polystyrene oligomers solvated in toluene. Can anybody please tell me where should I start? I am looking for relevant tutorials on how to:
1. grow a single polymer chain
2. pack a few of the polymer chains in a box
3. insert the solvent molecules
4. select an appropriate force-field for the polystyrene and the toluene
5. Relax the conformation
5. carry out the equilibrium MD simulations in a remote (LINUX) cluster
I guess doing these tutorials should put me in a very good footing. Please let me know.
Thanks in advance,
Jose Borreguero
Hi
There are several tutorials that are relevant, but probably one to look at is "Miscibility of polymers" - the name might be slightly different (as I am working from memory) but if you look in the online help in the tutorials section you will find it. This uses the polymer builder (to create the polymer) and the amorphous cell module for packing the polymers into a box. You can use amorphous cell module to pack both the polymer chains and toluene into a box. The tutorial also describes Geometry Optimization (to relax the initial box) and then molecular dynamics. There are probably some prerequisites (listed at the start of the tutorials) so I suggest that you follow those first. As for running on a LINUX cluster, so long as it has already been installed correctly this will just be an option on the job control panel in Forcite. COMPASS would be my first choice for the forcefield as Toluene was part of the training set and has been used for Polystryene. Here is a link to paper that uses Materials Studio to look at polyvinylmethylether/polystyrene mixtures.
Regards
Simon
Hi Simon,
I found the tutorial "Calculating the miscibility of two polymers", which does use "Amorphous Cell". Is this the one you referred to?
-Jose
Yes. It is different that what you want to do but uses the modules that you need.
S.
I just ran the tutorial with no troubles. I guess it's time to begin trying to build my more complex system. Thanks a ton!
