Dear all,
The calculation was failed in the multi core environment with the linux server.
On the other hand, the single core calculation has no problem.
There was any error message in the Materials Studio, when the calculation failed.
So I attached the retained file from the gateway.
It would be grateful if anyone would let me know.
Thank you.
There is really nothing in the log files which indicates why this run failed.
The CentOS version is the same on all nodes?
Is passwordless ssh possible on each involved node?
What do CASTEP and DMol3 give?
Do things work without the queuing system?
"BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES" is a notorious Intel MPI message, https://www.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/troubleshooting/error-message-bad-termination.html
All it means is that one of the processes crashed, and most likely the problem is an incompatibility of sorts between the Intel MPI version and your hardware/OS/queuing system. As Carsten says, check if you can run CASTDEP or DMol3 in parallel. If every server crashes in this fashion, you could try to reconfigure your MS 2022 to use a different MPI installation (if there is one on your computer): use web interface to change mpicommand setting to point to a local MPI installation. This might help...
