MSD ?
I tried amorphous cell construction to construct the composite structure after minimizing energy and optimizing the geometry and equilibration of my system
But I found it difficult when I started the MSD then and i can't obtain the mechanical properties for the .xtd file-the run button is not activated.
Answers 5
CM
CM 2021-02-05
Just to be sure the .xtd file is the result after the equilibration?
Run button is not activated:
How many frames does the trajectory have?
ZN
ZN 2021-02-08
thank you for replying
number of frames 1
​​​​​​​how i can change number of frame ?
CM
CM 2021-02-09
You have to do a longer run (with the same output frequency) or request to output frames more frequently. Or even both.
The MSD of which particles/molecules in your system do you want to calculate?
ZN
ZN 2021-02-09
Carstes MENKE        I want to calculate the MDS of (fe2o3 / Polymer).
 A box of one chain of Polymer and one Fe2O3 molecul by density of 1 g/ cm
Output is 1 frames / polymer loading is 1 / Fe2O3 loading is 1
CM
CM 2021-02-10
Could you please attach the .xsd file with the system to the post.
