MS Geometric Optimization
Hello, teachers. I am a beginner in MS and I am currently learning to build a cross-linking model. May I ask if after building the monomer model and adding the force field and charges, do I need to optimize the geometry of the monomers? I know that for the subsequent construction of the AC model, geometric optimization is required before using the script for cross-linking. Therefore, I have some doubts about the geometric optimization.
Answers 2
TM
TM 2026-01-26
1. Prepare Monomers
Yes, the geometry optimization of monomers is strongly recommended. Generally speaking in molecular simulation, when creating complex structures, structural optimization is performed starting from the smallest components.
2. Optimize Periodic Amorphous Structure
Indeed the geometry optimization is carried out with the default settings in Amorphous Cell (AC); please see the "Optimize geometry" checked in the "Amorphous Cell Options dialog". But only single core is used in AC. You can skip the geometry optimization in AC and do it in Forcite using multiple cores, as partially explained in the following online help tutorial,
    Tutorials > Forcite Plus tutorials > Calculating the diffusivity of a gas in a polymer
JD
JD 2026-01-26
Hi Bowen,
When I create a box of molecules for use in a crosslinking simulation I do not usually need to do any extra geometry optimization. That is because Amorphous Cell takes care of it for me. It generates conformations of the input molecules from scratch as it inserts them into the box. Then after the box is filled, it runs a geometry optimization and this in most cases brings the energy down enough that a dynamics run will be stable. So it can directly be passed on to the crosslinking script, for which you can specify the equilibration time.
Best,
Jason
