Molecule Selection
I have a system containing multiple different hydrocarbons and I want to select only one type (e.g. selecting methane out of a mixture of methane, ethane, and butane). Is there a simple way to do this without doing it manually? I've tried atom selection, but the molecules don't exhibit properties that make them distinguishable among the ways in which you can differentiate using atom selection.
Answers 3
CM
CM 2015-04-28
Please use Edit->Find Patterns for this. Use the Help button there to get further into how to use it. Please also have a look at the Materials Visualizer > Selecting objects and groups of objects > Finding patterns section in the help.
Basically, you need 3 documents. One for each molecule which you want to find.
NS
NS 2015-04-28
My problem with this approach is that it is not all-inclusive. The find pattern method will select only the molecules I am interested in, but it doesn't necessarily select ALL of the molecules I am trying to highlight. I'm wondering if since I'm running dynamics simulations in Forcite if some of these molecules are perceived as "images" due to periodic booundary conditions and are not selected in the find pattern process. This then contradicts the definition of periodic boundary conditions and images... The hypothesis is then further confused by the fact that the find pattern method still isn't all inclusive even on the first frame.
RA
RA 2015-05-01
Hi Nick,
The Find Pattern tool creates substructures on the original set of atoms, regardless of the displayed set of atoms.
To see the original set of atoms (aka asymmetric unit), change the display style of the lattice to Original.
To select the matches amongst the displayed set of atoms, run Find Patterns, right-click Select Substructure Items (i.e. the atoms), right-click Select Symmetry Images.
In most applications (e.g. Forcite Analysis) it does not matter which symmetry image is selected, even allowing for duplicates.
Hope this makes sense.
Reinier
