Mesocite, micellar aggregation
Dear colleagues,
I would like to inquire whether there are any existing scripts or other computational approaches to determine the number of clusters in Mesocite. For instance, after performing DPD simulations to observe micelle formation, I need to analyze the resulting aggregates—specifically, their quantity and aggregation numbers.
Any guidance or references would be greatly appreciated.
Answers 1
TG
TG 2025-05-06
Dear Andrew,
Starting from BIOVIA Materials Studio 2025, there is an out of the box script called "Ion Cluster Population Analysis" (ICPA) that can count clusters made of anions and cations and return a heat map for the population of each ion pair cluster (counts of anions and cations in the cluster). You can run this analysis using Tools -> Materials Studio Scripts -> Analyses -> Ion Cluster Population Analysis. However I'm not aware of a script for simple Cluster Population Analysis. You may take a look at the ICPA script for inspiration to create your own script for neutral molecules (which is a simpler problem as it only involves a single species).
Hope it helps,
Best regards,
Théophile.
