Please Can anyone help me explain the Melt-quench method or the anneal method to convert crystal models to amorphous in Material studio or other. I read the manual but couldn't really make it happen.
Can you send me an example of such work; a step by step example?
Merry christmas to all. Thank you!
Hi Raj,
Is this in the context of an amorphous inorganic material like silica? Note we have a few amorphous inorganics available in the Structures\glasses folder which can be useful at least as a point of reference. I would think generally heating things up should point you in the right direction. We do have Anneal and Quench tasks available in Forcite for some automated temperature schedules. What temperature are you using? Is it still visually obvious that it is a crystal even at very high temperatures above the melting point? If it is a particularly stable (stubborn) crystal, what about building a glass from scratch using AmCell?
Best,
/Jason
Thanks Jason
In my work I try to measure th eloading of CO2 in silica. I have carried oot some loading, but I see th eloading is too small compared to the experiment.
My question is
Thanks please. Answer this and be a life saver.
Hi Raj,
How about verifying that the density and radial distribution functions of the silica base are consistent with the experimental structure?
Best,
/Jason
Please sir
How do I do this. I remeber correcting the density of the model to 2.205g/cm3( value in literature). About the radial distribution function I don't know how to do that. Can you please expanciate. WHile I will be checking on that. Thanks
