I want to calculate the mechanical properties of a polymer at different temperatures, above and below the glass transition temperature. How can I do this? should I change the temperature when I am performing the NPT and/or NVT dynamics to my desired temperature and then use the mechanical properties in forcite? does this work? or is there any way to apply the desired temperature while calculating the mechanical properties using forcite?
Many thanks,
Melika
IN which properties are you interested?
Which Materials Studio version do you use?
Dear Carsten MENKE,
Thank you for your reply. I would like to calculate the Poisson ratio and the Young modulus. I am using Materials Studio 2017.
I also have another question. Is ther a way of decreasing the temperature of your simulation in NPT by a temperature ramp?
for example for calculating the Tg of PLA, after geometry optimization and equilibration at NVT followed by NPT at 1 atm and 600 K temperature, I want to decrease the temperature of the system in NPT at a specific rate for example 1k/ps to a temperature of 100K, and then draw the relationship between temperature and density of the system to obtain the Tg. is this possible? or should I perform a series of independent, consecutive dynamics at NPT each at a decreased temperature with respect to the previous stage?
Hi Melika,
There is a tutorial "Calculating the glass transition temperature using Pipeline Pilot" that does exactly as you describe: it determines Tg of PLA by tracking the density under a temperature ramp with NPT simulations.
If you do not have Pipeline Pilot, you can also do it manually, by running Forcite NPT simulations over a range of temperatures, and look for the inflection point in density. There are also some scripts on this community to automate this: e.g. Automate calculations for estimating glass transition temperature in polymers.
Good luck,
Reinier
Dear Reinier AKKERMANS, Thank you for your reply and help. I have solved the problem with calculating Tg and I got help from the script you mentioned so thank you very much.
but my original question remains still. I want to calculate the young modulus of my polymer once in the glass phase and once in the rubber phase. Should I equilibrate the system at for example 500 K which is about 200K above the Tg and then use the mechanical properties calculation of FORCITE to calculate young modulus? does this work? Does this actually give me the young modulus at this elevated T? I mean does the temperature remain 500K while the mechanical properties are being computed in this module using the constant strain method? I have equilibrated my system at 500 K but nothing in the chains indicates that there has been any significant change in the polymer. the system doesn't look that much different from when I equilibrated it at 280K. should I be able to see any difference in the appearance of the chains in the simulation box at these two temperatures?
