Hello,everyone
I am a new user of MS script and hope some experienced users can give me some advice.
I want to simulate the melting point of LiCl-KCl by cooling it from 723K to another lower temperature with a Perl script to observe the MSD (or density or some other property of it).
Here is my code:
#!perl
use strict;
use Getopt::Long;
use MaterialsScript qw(:all);
my \\\$deltaT=20;
my \\\$Tempchangetimes=1;
my \\\$NumberOfSteps = 20000;
my \\\$doc = \\\$Documents{"H2O.xsd"};
my \\\$newdoc = Documents->New("Hello.xtd");
sub Run {
my (\\\$doc) = @_;
my \\\$forcite = Modules->Forcite;
my \\\$dynamics = Modules->Forcite->Dynamics;
for (my \\\$i = 0) {
\\\$forcite->ChangeSettings([
Ensemble3D =>"NVT",
CurrentForcefield => "COMPASS", # force field to be used in the simulations
Temperature=>723-\\\$deltaT*\\\$i,
Thermostat => "Nose", # type of thermostat to use
BerendsenThermostatDecayConstant => 0.1, # thermostat parameter
"3DPeriodicvdWSummationMethod" => "Atom based", # van der Waals method to use
TimeStep => 1, # time step (in fs)
NumberOfSteps => \\\$NumberOfSteps,
my \\\$results = Modules->Forcite->Dynamics->Run(\\\$doc, \\\$forcite);
my \\\$docdelete = \\\$Documents{"H2O.xtd"};
\\\$newdoc->Trajectory->AppendFramesFrom(\\\$doc,Frames(Start=>1,End=>\\\$NumberOfSteps));
\\\$docdelete->Delete;
for (my \\\$i = 1; \\\$i <= \\\$Tempchangetimes; ++\\\$i) {
Ensemble3D =>"NVT",
InitialVelocities => "Current"
But when i analyze the MSD of the xtd file, it shows "Mean square displacement analysis failed. The times associated with the first two selected fames are both zero"
I guess it because all the trajectories are counted from zero not continued.
Are there any method can fixed this problem??
Thanks in advance,
Regards,
Bill
