Hello everyone
I am newcomer to material studio.
I want to simulate water in 298 K an 1 atm.
I know the steps of MD but I dont know the accurate ensembles and barostats and thermosats.
What should I do in equilibrium and production steps to reach 298 K an 1 atm?
I need some explanation about the MD procedure.
Hi jab,
I usually first run 50-100 ps NVT, with NHL thermostat and Q-ratio = 1. Then continue with NPT, using the Andersen barostat (p = 0.000101325 GPa) with default settings for a similar period, followed by a production run.
Other people may have other preferences. The Nose thermostat has a tendency to give temperature oscillations when applied to non-equilibrium structures; if using for equilibration a smaller Q-ratio (e.g. 0.01) is recommended. Velocity scale, Berendsen, Andersen thermostats are OK for equilibration, but can impact the dynamics, and I would not use them when calculating dynamic properties (e.g. mean square displacements).
More details can be found in the topics "Temperature" and "Pressure and stress" in the Dynamics theory section. You may also want to go throught the Forcite Plus tutorials.
Hope this helps,
Reinier
Hi Reinier
When we run NVT with NHL thermostat, if the Q-ratio = 0.01, will the system be equilibriated faster? If we run NVT for the whole simulation, how about use Q=0.01 for equilibrium and Q = 1 for production?
Regards,
Jingjing
Hi Jab,
For my simulations which are in different tempratures and 1 atm, for each temperatues firstly I performed 100Ps NPT at P=0.0001 GPa, then 150 Ps NVT for equiblaration, finally 1Ns NVE run for calculating MSD. However, I'm not sure if the procedure is right or not.
Best,
Sheida
We have water and 1-octanol, if we add trace amount of water to 1-octanol
then this water will solve, but if follow water addition to 1-octanol in
one point the water will not solve, in this point the phase seperation
tacke place and the two liquid phase will occur. Is there any method in
material studio to predict this point?
Thanks
On Sun, Apr 27, 2014 at 1:58 PM, Reinier Akkermans
With the NHL thermostat it is no longer necessary to change the Q-ratio, as it has a dissipative term that damps oscillations sometimes seen with Nose thermostat at too high Q-ratio. A value of 1 is recommended, although changing it to 0.01 for equilibration is probably OK too.
