Materials Studio 2024 COMPASS force-field parameters missing for AlCl₄⁻ and Al₂Cl₇⁻
Hello everyone, when I was using the forcite module in MS 2024 to perform geometric optimization on chloroaluminate ions, I found that there were no force field options for AlCl₄⁻ and Al₂Cl₇⁻ when using the COMPASS force field. Even the general force field did not include these options. As you know, the COMPASS force field cannot be manually customized to add force field parameters. In this case, how can I manually add force field parameters?
Answers 3
CM
CM 2026-09-04
I suggest to have a look at the "Using Materials Studio to edit a forcefield" tutorial.
There Dreiding is modified.
In which kind of results are you interested at the end?
JL
JL 2026-09-04
Adding forcefield parameters to an existing forcefield shouldn’t be taken lightly.  There a reason why scientists who developed/published forcefields earned so much respect.  For your case, you may want to start with the Universal forcefield (UFF), that by definition covers all species derived from elements in the periodic table.  You may be amazed by the extent UFF can accommodate, particularly in an exploring stage of a new project.
Hope it helps,
Jian-jie
JD
JD 2026-09-04
Hi cheng zha,
We did add some new types and parameters to broaden the coverage of ionic liquids over the last few releases, but not for aluminum unfortunately. I wonder if you could change the aluminum to a carbon as a rough approximation. Then do some DMol3 (on the real compounds) to calculate partial charges and serve as a point of reference for the correct geometry.
