MARTINI Polarizable Water Model
Has anyone added the three bead types W0, W+, and W- to the MS MARTINI implementation for polarizable water?  If so, what is involved?  If not, any ideas on haw this could be accomplished?
Anthony
Answers 4
JD
JD 2012-07-26
Hi Anthony,
See the attachment.To the standard MS Martini I have added or changed:
  1. Two new types (W, WPM)
  2. One new bond
  3. One new angle
  4. One new vdw (W, W)
  5. Dielectric constant
  6. vdw equivalence W=>P4
Best,
/Jason
comment imagecomment imagecomment imagecomment image
AD
AD 2012-07-27
Thank you, Jason.  Very helpful.
Anthony
AD
AD 2012-08-02
Hi Jason,
I just noticed that in your changes for MARTINI polarizable water you equivalenced the neutral particle W to P4.  The W-W interaction strength in this case would be at level I which corresponds to 5.0 kJ/mol.  In my reading of the polarizable model paper by Marrink et al, the final W-W interaction strength is set to 4.0 kJ/mol, corresponding to a level III interaction.  Setting the equivalence to P4 would result in an interaction that is too atractive and would increase the density and not reproduce the correct hydration free energy of water.  Can you please check this and indicate if you agree?
Regards,
Anthony
JD
JD 2012-08-02
I agree. It should be changed to a level 2 equivalence. That way the explicit W-W interaction will not be ignored, but all of the other interactions W-X where X is anything but W will be substituted with the P4-X parameters.
