inverting chiral center in MS
Can anyone here suggest me a way to change the chiral center of a molecule in material studio ? For e-g. I want to flip the alpha anomeric center into beta anomeric center. It is easy to work with in cerius 2 but I am having trouble in Material studio in figuring out a technique. I would appreciate any suggestions.
Thanks
-naseer
Answers 3
JD
JD 2011-09-19
Hi Naseer,
You will have to do this visually. For example you can select an atom and move it using Shift-Alt-Rightmouse. Use the arrows to rotate the display in 45 deg increments. Use torsion or angle monitors to change internal coords.
Best,
/Jason
HP
HP 2011-09-26
Hey Jason,
Thanks for the reply. The suggestion is good only if you are going to change the chirality of one particular group. Also this type of technique adds up additional task like cleaning of neighbouring atom and this will become more complicated when you have many units in a polymers that need to be inverted. I have used the chiral inversion operation in cerius2 berfore that was pretty simple to work with.
FH
FH 2011-09-26
Only as a comment and suggestion to the developer team of MS: It is interesting that this function is already incorporated in the freeware product DS Visualizer but not yet implemented into the high-priced product MS. Are there special reasons for that?
kind regards
Frank
