Interaction Energy Calculations
Dear MS Community,
I am simulating crystallization of drugs in different antisolvent systems. For deeper insights, I need to calculate interaction energies among various species in the system. I am referring to Table-1 of the following journal:
Any help will be appreciated.
Answers 2
JL
JL 2025-03-27
You may use thermodynamic cycle for your purpose.  Refer to, e.g., the MS help manual, under,
Theory > Solvation free energy theory
Tutorials > DMol3 tutorials > Calculating the free energies of chemical reactions
Hope it helps,
Jian-jie
RA
RA 2025-04-04
Looking at the videos in the supporting information, e.g.
 They have simulated 2 solute molecules in 500 solvent using dynamics.
To get the average solute-solute interaction energy, you could create a new trajectory without the solvent, and run an energy calculation on that. This is best done in scripting.
To exclude the intramolecular energy, add motion groups to each solute molecule, and set
    KeepMotionGroupsRigid => 'Yes',
    IgnoreMotionGroupInvariantTerms => 'Yes',
This should give you the last column in Table 1, let's call it E_cc.
Repeat this for the average solvent-solvent interaction, E_ss. Now you can obtain the average solvent-solute interaction as E - E_cc - E_ss, where E is the total intermolecular energy.
Have a look at the tutorial "Using scripting to calculate the interaction energy between two layers", which does something similar.
Good luck,
Reinier
