Hi Dear All
I tried to calculate interaction energy between a layer of clay and the solute ions. I used Jason's revised script. But I still got the problem met by other people mentioned, the interaction energy I calculated between four solute ions and the clay was almost four time larger than the interaction energy calculated between one solute ion and the clay.
Could you please help me out with that? What's the problem here? Thank you very much!
# The trajectory document
my \\\$filename = \\\$doc->Name;
my \\\$doc = \\\$Documents{"\\\$filename.xtd"};
# Loop over every pair of sets
# Get the total number of frames in the trajectory
my \\\$numFrames = \\\$doc->Trajectory->NumFrames;
if (\\\$lastframe == 0) { \\\$lastframe = \\\$numFrames; }
print "Calculating interaction energy from frame \\\$firstframe to \\\$lastframe on \\\$filename trajectory\\n";
# Starts to loop over the frames in the trajectory
# Calculate the averages
\\\$avgSheet->ColumnHeading(0) = "Interaction";
\\\$avgSheet->ColumnHeading(1) = "Interaction Energy (kcal/mol)";
\\\$avgSheet->ColumnHeading(2) = "n";
\\\$avgSheet->ColumnHeading(3) = "StdDev";
\\\$avgSheet->ColumnHeading(4) = "StdErr";
\\\$avgSheet->ColumnHeading(5) = "vdW Interaction Energy (kcal/mol)";
\\\$avgSheet->ColumnHeading(6) = "n";
\\\$avgSheet->ColumnHeading(7) = "StdDev";
\\\$avgSheet->ColumnHeading(8) = "StdErr";
\\\$avgSheet->ColumnHeading(9) = "Coulomb Interaction Energy (kcal/mol)";
\\\$avgSheet->ColumnHeading(10) = "n";
\\\$avgSheet->ColumnHeading(11) = "StdDev";
\\\$avgSheet->ColumnHeading(12) = "StdErr";
if (\\\$ObjectType eq "Atom")
\\\$avgSheet->ColumnHeading(13) = "Hbonds";
\\\$avgSheet->ColumnHeading(14) = "n";
\\\$avgSheet->ColumnHeading(15) = "StdDev";
\\\$avgSheet->ColumnHeading(16) = "StdErr";
my \\\$col_a = 17;
my \\\$col_b = 20;
\\\$col_b-- unless (\\\$ObjectType eq "Atom");
for (my \\\$pair=1; \\\$pair<\\\$newStudyTable->Sheets->Count; \\\$pair++)
my \\\$sheet = \\\$newStudyTable->Sheets(\\\$pair);
\\\$avgSheet->Cell(\\\$pair-1, 0) = \\\$sheet->Title;
for (my \\\$col=\\\$col_a; \\\$col<=\\\$col_b; \\\$col++)
my \\\$n=0; my \\\$avg=0; my \\\$msq=0;
for (my \\\$i=0; \\\$i<\\\$sheet->RowCount; \\\$i++)
my \\\$value;
eval { \\\$value = \\\$sheet->Cell(\\\$i, \\\$col); };
last if (\\\$@);
last if (\\\$value eq "");
\\\$avg+=\\\$value;
\\\$msq+=(\\\$value*\\\$value);
\\\$n++;
\\\$avg/=\\\$n;
\\\$msq/=\\\$n;
my \\\$var = \\\$msq - \\\$avg*\\\$avg;
my \\\$colout = 4*(\\\$col-\\\$col_a)+1;
\\\$avgSheet->Cell(\\\$pair-1, \\\$colout) = \\\$avg;
\\\$avgSheet->Cell(\\\$pair-1, 1+\\\$colout) = \\\$n;
\\\$avgSheet->Cell(\\\$pair-1, 2+\\\$colout) = sqrt(\\\$var);
\\\$avgSheet->Cell(\\\$pair-1, 3+\\\$colout) = sqrt(\\\$var/\\\$n);
print "Calculation complete!\\n";
sub SetsAreOK
my (\\\$doc, \\\$ObjectType) = @_;
my \\\$objects = \\\$ObjectType ."s";
my \\\$items = \\\$doc->UnitCell->\\\$objects;
my \\\$sets = \\\$doc->UnitCell->Sets;
# Get the total number of atoms or beads
my \\\$total = \\\$items->Count;
Regards,
Jingjing
#!perl
use strict;
use Getopt::Long;
use MaterialsScript qw(:all);
use Getopt::Long;
# Authors: Stephen Todd, Jason DeJoannis
# Date: Apr. 22, 2013
# Purpose: Interaction energies between each pair of sets
# Requirements: Trajectory with sets defined
# The sets must be non-overlapping (no two can contain the same atom or bead)
# A Forcite/Mesocite settings file with the same name as the trajectory
# Works for Forcite or Mesocite and with standard MS or OFF forcefields
# Outputs: A study table with a summary page and one page for each interaction
# van der Waals and Coulomb energy components
# Hydrogen bond counts
# Begin user settings
# These are for the user menu
my \\\$doc = Documents->ActiveDocument;
my %Arg;
GetOptions(\\%Arg, "Forcefield_file=s", "First_frame=i", "Last_frame=i",
"Write_structure_frequency=i");
my \\\$forcefield = \\\$Arg{"Forcefield_file"}; # Leave blank for standard MS ff specified via settings file
my \\\$firstframe = \\\$Arg{"First_frame"}; # Frame to start from
my \\\$lastframe = \\\$Arg{"Last_frame"}; # Frame to end on, 0=last
my \\\$structFreq = \\\$Arg{"Write_structure_frequency"}; # Frequency for writing structure to table, 0=none
my %Arg;
# Comment the above lines and uncomment these to run from script editor
#my \\\$doc = \\\$Documents{"test.xtd"};
#my \\\$forcefield = "";
#my \\\$firstframe = 1;
#my \\\$lastframe = 0;
#my \\\$structFreq = 10;
# End user settings
# End user settings
# Automatically detect Forcite or Mesocite
my \\\$module = Modules->Forcite;
my \\\$ObjectType = "Atom";
if (\\\$doc->UnitCell->Beads->Count > \\\$doc->UnitCell->Atoms->Count)
\\\$module = Modules->Mesocite;
\\\$ObjectType = "Bead";
my \\\$ObjectTypes = \\\$ObjectType . "s";
# Check sets are ok
die "The sets must be mutually exclusive and non-empty\\n" unless SetsAreOK(\\\$doc, \\\$ObjectType);
# The energy settings
\\\$module->LoadSettings(\\\$filename);
if (\\\$forcefield ne "")
\\\$forcefield =~ s/\\.off\\\$//;
\\\$module->ChangeSettings([CurrentForcefield => "/\\\$forcefield"]);
print "Using OFF forcefield \\\$forcefield\\n";
# Create a new study table to hold the structures and energies and set the headings
my \\\$newStudyTable = Documents->New("\\\$filename"."_IntEnergy.std");
my \\\$avgSheet = \\\$newStudyTable->Sheets->Item(0);
\\\$avgSheet->Title = "Statistics";
# Create an array with all the set names
my \\\$maxsets = 4; # adjustable
my \\\$nsets = \\\$doc->UnitCell->Sets->Count;
if (\\\$nsets > \\\$maxsets) { \\\$nsets = \\\$maxsets; }
my @setname;
for (my \\\$i=0; \\\$i<\\\$nsets; \\\$i++)
push @setname, \\\$doc->UnitCell->Sets(\\\$i)->Name;
my @setname;
for (my \\\$i=0; \\\$i<@setname; \\\$i++)
my \\\$setname1 = \\\$setname[\\\$i];
for (my \\\$j=\\\$i+1; \\\$j<@setname; \\\$j++)
my \\\$setname2 = \\\$setname[\\\$j];
printf "Interactions between sets %s and %s\\n", \\\$setname1, \\\$setname2;
my \\\$calcSheet = \\\$newStudyTable->InsertSheet;
\\\$calcSheet->Title = "\\\$setname1 + \\\$setname2";
\\\$calcSheet->ColumnHeading(0) = "Frame";
\\\$calcSheet->ColumnHeading(1) = "Time (ps)";
\\\$calcSheet->ColumnHeading(2) = "\\\$setname1 + \\\$setname2";
\\\$calcSheet->ColumnHeading(3) = "Energy of \\\$setname1 + \\\$setname2";
\\\$calcSheet->ColumnHeading(4) = "vdW Energy of \\\$setname1 + \\\$setname2";
\\\$calcSheet->ColumnHeading(5) = "Coulomb Energy of \\\$setname1 + \\\$setname2";
\\\$calcSheet->ColumnHeading(6) = "Hbonds \\\$setname1 + \\\$setname2" if (\\\$ObjectType eq "Atom");
\\\$calcSheet->ColumnHeading(7) = "\\\$setname1";
\\\$calcSheet->ColumnHeading(8) = "Energy of \\\$setname1";
\\\$calcSheet->ColumnHeading(9) = "vdW Energy of \\\$setname1";
\\\$calcSheet->ColumnHeading(10) = "Coulomb Energy of \\\$setname1";
\\\$calcSheet->ColumnHeading(11) = "Hbonds \\\$setname1" if (\\\$ObjectType eq "Atom");
\\\$calcSheet->ColumnHeading(12) = "\\\$setname2";
\\\$calcSheet->ColumnHeading(13) = "Energy of \\\$setname2";
\\\$calcSheet->ColumnHeading(14) = "vdW Energy of \\\$setname2";
\\\$calcSheet->ColumnHeading(15) = "Coulomb Energy of \\\$setname2";
\\\$calcSheet->ColumnHeading(16) = "Hbonds \\\$setname2" if (\\\$ObjectType eq "Atom");
\\\$calcSheet->ColumnHeading(17) = "Interaction Energy \\\$setname1 \\\$setname2";
\\\$calcSheet->ColumnHeading(18) = "vdW Interaction Energy \\\$setname1 \\\$setname2";
\\\$calcSheet->ColumnHeading(19) = "Coulomb Interaction Energy \\\$setname1 \\\$setname2";
\\\$calcSheet->ColumnHeading(20) = "Hbonds between \\\$setname1 \\\$setname2" if (\\\$ObjectType eq "Atom");
for ( my \\\$count=\\\$firstframe; \\\$count<=\\\$lastframe; \\\$count++)
print "Calculating energy for frame \\\$count\\n";
# Define the frame of the trajectory
\\\$doc->Trajectorys->Item(0)->CurrentFrame = \\\$count;
# Create three documents to hold the temporary layers
my \\\$bothDoc = Documents->New("both.xsd");
my \\\$set1Doc = Documents->New("set1.xsd");
my \\\$set2Doc = Documents->New("set2.xsd");
# Create a copy of the structure in temporary documents and delete
# the atoms or beads we don't need. This way bonds are preserved.
\\\$bothDoc->CopyFrom(\\\$doc);
my \\\$cell = \\\$bothDoc->UnitCell;
my \\\$objects = \\\$cell->\\\$ObjectTypes;
foreach (@{\\\$objects}) { \\\$_->Name = "Delete"; }
foreach (@{\\\$cell->Sets(\\\$i)->\\\$ObjectTypes}) { \\\$_->Name = "Keep"; }
foreach (@{\\\$cell->Sets(\\\$j)->\\\$ObjectTypes}) { \\\$_->Name = "Keep"; }
foreach (@{\\\$objects}) { \\\$_->Delete if (\\\$_->Name eq "Delete"); }
\\\$set1Doc->CopyFrom(\\\$doc);
my \\\$cell = \\\$set1Doc->UnitCell;
\\\$set2Doc->CopyFrom(\\\$doc);
my \\\$cell = \\\$set2Doc->UnitCell;
# Calculate the energies for each grouping
\\\$module->Energy->Run(\\\$bothDoc);
\\\$module->Energy->Run(\\\$set1Doc);
\\\$module->Energy->Run(\\\$set2Doc);
# Calculate hydrogen bonds
\\\$bothDoc->CalculateHBonds;
\\\$set1Doc->CalculateHBonds;
\\\$set2Doc->CalculateHBonds;
# Frame number
my \\\$row = \\\$count - \\\$firstframe;
\\\$calcSheet->Cell(\\\$row, 0) = \\\$doc->Trajectorys->Item(0)->CurrentFrame;
\\\$calcSheet->Cell(\\\$row, 1) = \\\$doc->Trajectorys->Item(0)->FrameTime;
# Put the structures in a study table for safekeeping
if (\\\$structFreq > 0 and \\\$row % \\\$structFreq == 0)
\\\$calcSheet->Cell(\\\$row, 2) = \\\$bothDoc;
\\\$calcSheet->Cell(\\\$row, 7) = \\\$set1Doc;
\\\$calcSheet->Cell(\\\$row, 12) = \\\$set2Doc;
# Individual energies
\\\$calcSheet->Cell(\\\$row, 3) = \\\$bothDoc->PotentialEnergy;
\\\$calcSheet->Cell(\\\$row, 4) = \\\$bothDoc->vanderWaalsEnergy;
\\\$calcSheet->Cell(\\\$row, 5) = \\\$bothDoc->ElectrostaticEnergy;
\\\$calcSheet->Cell(\\\$row, 6) = \\\$bothDoc->UnitCell->HydrogenBonds->Count if (\\\$ObjectType eq "Atom");
\\\$calcSheet->Cell(\\\$row, 8) = \\\$set1Doc->PotentialEnergy;
\\\$calcSheet->Cell(\\\$row, 9) = \\\$set1Doc->vanderWaalsEnergy;
\\\$calcSheet->Cell(\\\$row, 10) = \\\$set1Doc->ElectrostaticEnergy;
\\\$calcSheet->Cell(\\\$row, 11) = \\\$set1Doc->UnitCell->HydrogenBonds->Count if (\\\$ObjectType eq "Atom");
\\\$calcSheet->Cell(\\\$row, 13) = \\\$set2Doc->PotentialEnergy;
\\\$calcSheet->Cell(\\\$row, 14) = \\\$set2Doc->vanderWaalsEnergy;
\\\$calcSheet->Cell(\\\$row, 15) = \\\$set2Doc->ElectrostaticEnergy;
\\\$calcSheet->Cell(\\\$row, 16) = \\\$set2Doc->UnitCell->HydrogenBonds->Count if (\\\$ObjectType eq "Atom");
# Interaction energies
my \\\$col=17;
foreach my \\\$component ("PotentialEnergy", "vanderWaalsEnergy", "ElectrostaticEnergy")
my \\\$interaction = \\\$bothDoc->\\\$component - \\\$set1Doc->\\\$component - \\\$set2Doc->\\\$component;
\\\$calcSheet->Cell(\\\$row, \\\$col) = \\\$interaction;
\\\$col++;
\\\$calcSheet->Cell(\\\$row, 20) = \\\$bothDoc->UnitCell->HydrogenBonds->Count
- \\\$set1Doc->UnitCell->HydrogenBonds->Count
- \\\$set2Doc->UnitCell->HydrogenBonds->Count if (\\\$ObjectType eq "Atom");
# Discard the temporary documents
\\\$bothDoc->Discard;
\\\$set1Doc->Discard;
\\\$set2Doc->Discard;
my \\\$col=17;
\\\$col++;
} #next frame
}# next j
}# next i
}# next i
my \\\$col_a = 17;
my \\\$col_b = 20;
my \\\$value;
last if (\\\$@);
\\\$avg+=\\\$value;
\\\$n++;
\\\$avg/=\\\$n;
\\\$msq/=\\\$n;
sub SetsAreOK
# Cache their names
my @name;
foreach my \\\$item (@{\\\$items})
push @name, \\\$item->Name;
# Go through each set and each item and rename them
my \\\$tot_in_sets=0;
foreach my \\\$set (@{\\\$sets})
my \\\$items = \\\$set->\\\$objects;
my \\\$n = \\\$items->Count;
if (\\\$n == 0)
print "Set ".\\\$set->Name." is empty (UnitCell)\\n";
return 0;
\\\$tot_in_sets += \\\$n;
if (\\\$item->Name =~ /^Member of set /)
my \\\$otherset = \\\$item->Name;
\\\$otherset =~ s/^Member of set //;
print "Overlap between sets ".\\\$set->Name." and \\\$otherset\\n";
return 0;
\\\$item->Name = "Member of set ".\\\$set->Name;
# Put their names back
my \\\$i=0;
\\\$item->Name = \\\$name[\\\$i];
\\\$i++;
if (\\\$total < \\\$tot_in_sets)
print "More \\\$objects in sets than in document\\n";
return 0;
return 1;
my @name;
if (\\\$n == 0)
return 0;
return 0;
my \\\$i=0;
\\\$i++;
return 0;
return 1;
Regards,
Jingjing
