Installation of MS 2024 in Ubuntu Linux
Hi community,
I saw the MS manual that Linux only supports CentOS version. I wonder if there is a way to install MS Linux version on Ubuntu? Thank you!
Answers 1
JL
JL 2024-03-29
Just in case you hadn’t noticed, MS supports Red Hat Enterprise Linux, as well, apart from flavors of OS on Windows platform.  I’d encourage you to consider dual/multiple-boot if that’s an option for you.  If you have no other choice but Ubuntu Linux, then MS will not prevent you from installing.  Just keep in mind that the OS is not supported, and you are on your own should you run into complications.
Hope it helps,
Jian-jie
