you can see the file of castep show the "***********"
+ Acoustic sum rule correction < 48.584409 cm-1 applied +
+ N Frequency irrep. ir intensity active raman intensity active +
+ (cm-1) ((D/A)**2/amu) (A**4) +
+ 1 -0.031332 a 0.0000000 N 0.0000000 N +
+ 2 -0.025363 b 0.0000000 N 0.0000000 N +
+ 3 -0.018034 c 0.0000000 N 0.0000000 N +
+ 4 105.194597 b 0.1168312 Y 0.0000000 N +
+ 5 124.437043 d 0.0000000 N 0.0000000 N +
+ 6 130.533362 c 4.7132418 Y 0.0000000 N +
+ 7 134.002179 e 0.0000000 N 26420254.4588089 Y +
+ 8 139.832350 d 0.0000000 N 0.0000000 N +
+ 9 145.434229 b 3.3278648 Y 0.0000000 N +
+ 10 153.317977 a 216.2305798 Y 0.0000000 N +
+ 11 169.041843 f 0.0000000 N 16450169.3177268 Y +
+ 12 169.101589 g 0.0000000 N 5750007.4101529 Y +
+ 13 169.237621 h 0.0000000 N 9001410.8756545 Y +
+ 14 173.529376 c 0.3653195 Y 0.0000000 N +
+ 15 182.280690 e 0.0000000 N 16516437.6113398 Y +
+ 16 200.125914 d 0.0000000 N 0.0000000 N +
+ 17 200.175740 h 0.0000000 N 144733.0959504 Y +
+ 18 206.856433 g 0.0000000 N 6528750.8550967 Y +
+ 19 208.822314 c 20.9913290 Y 0.0000000 N +
+ 20 210.567211 a 9.0889175 Y 0.0000000 N +
+ 21 212.665924 f 0.0000000 N 15867677.4115276 Y +
+ 22 213.284348 b 10.9428034 Y 0.0000000 N +
+ 23 227.928167 f 0.0000000 N 16666930.5185946 Y +
+ 24 230.701334 h 0.0000000 N 3721051.9032543 Y +
+ 25 232.521195 g 0.0000000 N 19851988.5765653 Y +
+ 26 237.430930 e 0.0000000 N 1916411.0973260 Y +
+ 27 248.877011 c 3.2779357 Y 0.0000000 N +
+ 28 255.439664 e 0.0000000 N 97341051.0074209 Y +
+ 29 277.677815 b 0.0059419 Y 0.0000000 N +
+ 30 279.100207 g 0.0000000 N 44731.1696503 Y +
+ 31 290.682514 g 0.0000000 N 647494.3426084 Y +
+ 32 303.047828 b 0.0615036 Y 0.0000000 N +
+ 33 307.723052 e 0.0000000 N 32617735.3881064 Y +
+ 34 313.660721 b 51.3196510 Y 0.0000000 N +
+ 35 317.421155 c 53.1071214 Y 0.0000000 N +
+ 36 320.318838 c 15.6438901 Y 0.0000000 N +
+ 37 330.679926 g 0.0000000 N 10986356.2874073 Y +
+ 38 333.971702 e 0.0000000 N 55198750.0371636 Y +
+ 39 368.313992 g 0.0000000 N 2803631.8368929 Y +
+ 40 368.796738 b 0.0946775 Y 0.0000000 N +
+ 41 371.871889 d 0.0000000 N 0.0000000 N +
+ 42 372.404931 a 13.0908584 Y 0.0000000 N +
+ 43 380.537087 e 0.0000000 N**************** Y +
+ 44 381.226070 h 0.0000000 N **************** Y +
+ 45 381.661648 f 0.0000000 N 54944474.6627546 Y +
+ 46 385.946666 g 0.0000000 N 2980582.9989499 Y +
+ 47 388.850536 c 52.8225818 Y 0.0000000 N +
+ 48 400.643514 e 0.0000000 N 98453368.7759200 Y +
+ 49 403.654885 b 57.0457853 Y 0.0000000 N +
+ 50 408.253437 c 137.7605864 Y 0.0000000 N +
+ 51 413.878264 f 0.0000000 N 67424376.7395308 Y +
+ 52 418.072675 d 0.0000000 N 0.0000000 N +
+ 53 421.349677 e 0.0000000 N 15434489.6500870 Y +
+ 54 424.403017 h 0.0000000 N **************** Y +
+ 55 424.838035 g 0.0000000 N 3500188.6059507 Y +
+ 56 425.666744 c 17.4674913 Y 0.0000000 N +
+ 57 435.667120 a 451.7405937 Y 0.0000000 N +
+ 58 443.374618 e 0.0000000 N 32909851.5229420 Y +
+ 59 444.234624 g 0.0000000 N 10323149.3673799 Y +
+ 60 451.752226 a 126.5950750 Y 0.0000000 N +
+ 61 454.186368 b 11.8040522 Y 0.0000000 N +
+ 62 473.810643 c 28.7516499 Y 0.0000000 N +
+ 63 478.608658 b 31.6952702 Y 0.0000000 N +
+ 64 482.793183 d 0.0000000 N 0.0000000 N +
+ 65 487.895603 h 0.0000000 N 91679314.9155910 Y +
+ 66 490.989027 f 0.0000000 N 1783457.3542348 Y +
+ 67 491.838001 g 0.0000000 N 5528788.7880954 Y +
+ 68 494.578988 e 0.0000000 N **************** Y +
+ 69 495.864446 c 1.3715704 Y 0.0000000 N +
+ 70 506.786813 d 0.0000000 N 0.0000000 N +
+ 71 507.964826 f 0.0000000 N 24096.8581404 Y +
+ 72 508.951221 e 0.0000000 N 38377539.9135744 Y +
+ 73 514.281010 b 1.8279541 Y 0.0000000 N +
+ 74 515.066952 h 0.0000000 N 84300955.3751235 Y +
+ 75 516.229000 g 0.0000000 N 16937379.9404979 Y +
+ 76 517.953599 b 138.4491601 Y 0.0000000 N +
+ 77 526.897551 a 15.7054759 Y 0.0000000 N +
+ 78 528.757318 g 0.0000000 N 45210844.7682824 Y +
+ 79 533.867833 e 0.0000000 N **************** Y +
+ 80 561.539013 c 15.5854015 Y 0.0000000 N +
+ 81 578.397321 b 99.2974538 Y 0.0000000 N +
+ 82 589.647348 c 60.7587036 Y 0.0000000 N +
+ 83 589.858903 e 0.0000000 N 46428204.1201273 Y +
+ 84 596.145638 g 0.0000000 N 1239120.4065363 Y +
First I optimised the struct(CaFe2O4),have no problem,follow the file of param
task : GeometryOptimization
comment : CASTEP calculation from Materials Studio
xc_functional : PBE
spin_polarized : false
opt_strategy : Default
page_wvfns : 0
cut_off_energy : 500.000000000000000
grid_scale : 1.750000000000000
fine_grid_scale : 2.100000000000000
finite_basis_corr : 2
finite_basis_npoints : 3
elec_energy_tol : 1.000000000000000e-006
max_scf_cycles : 500
fix_occupancy : true
nextra_bands : 0
num_dump_cycles : 0
geom_energy_tol : 1.000000000000000e-005
geom_force_tol : 0.030000000000000
geom_stress_tol : 0.050000000000000
geom_disp_tol : 1.000000000000000e-003
geom_max_iter : 200
geom_method : BFGS
fixed_npw : false
geom_modulus_est : 25.000000000000000 GPa
calculate_ELF : false
calculate_stress : true
popn_calculate : false
calculate_hirshfeld : false
calculate_densdiff : false
pdos_calculate_weights : false
Then I calculated the raman follow the file of efield param
task : Phonon+Efield
continuation : default
xc_functional : PBE
page_wvfns : 0
finite_basis_corr : 0
elec_energy_tol : 1.000000000000000e-010
elec_eigenvalue_tol : 1.000000000000000e-009
nextra_bands : 0
num_dump_cycles : 0
efield_ignore_molec_modes : crystal
efield_calc_ion_permittivity : true
phonon_max_cycles : 100
phonon_sum_rule_method : reciprocal
efield_energy_tol : 1.000000000000000e-005
excited_state_scissors : 0.000000000000000e+000
calculate_born_charges : true
born_charge_sum_rule : true
bs_max_iter : 250
efield_max_cycles : 500
calculate_raman : true
raman_range_low : 0.000000000000000e+000 cm-1
raman_range_high : 1.000000000000000e+004 cm-1
backup_interval : 900
bs_write_eigenvalues : false
xc_functional : PBE
page_wvfns : 0
nextra_bands : 0
num_dump_cycles : 0
geom_max_iter : 200
geom_method : BFGS
fixed_npw : false
xc_functional : PBE
page_wvfns : 0
nextra_bands : 0
num_dump_cycles : 0
bs_max_iter : 250
Please check if the system is perhaps not metallic. From the Materials Studio help:
Selecting Fix occupancy on the SCF tab of the CASTEP Electronic Options dialog uses fixed orbital occupancies. This is not sufficient if DFT results from a non-spin-polarized calculation indicate that the system under investigation is nonmetallic. Attempting to study a metallic system using fixed orbital occupancies results in poor convergence of the electric field response calculation. The symptoms are very large numbers for IR and Raman intensities and for polarizability in the output file. If this is the case, investigate whether your system is metallic by running either density of states or band structure calculations.
