Sorry if question might be a stupid one, but I am a beginner. I am actually using Material Studio on a remote machine. When I perform calculation with Discover on a local pc, I get SimulationEnergies.xcd file where I can observe the energy vs optimization steps. When I use the remote machine in the computer centre I get no such a file. In the remote view there is no xcd files.
Please tell me what am I doing wrong?
In the remote view I can find only these files:
<br>[DIR] Parent Directory - <br>[ ] Discover.log 21-Oct-2010 19:46 0 <br>[TXT] fromdsd.txt 21-Oct-2010 19:45 102 <br>[TXT] jobident.txt 21-Oct-2010 19:45 82 <br>[ ] pbs.sh 21-Oct-2010 19:46 1.1K <br>[TXT] stdout.txt 21-Oct-2010 19:46 111 <br>[TXT] todsd.txt 21-Oct-2010 19:46 142 <br>[ ] xray.car 21-Oct-2010 19:46 441K <br>[ ] xray.inp 21-Oct-2010 19:46 1.3K <br>[ ] xray.mdf 21-Oct-2010 19:46 479K <br>[ ] xray.out 21-Oct-2010 19:47 2.0K <br>[ ] xray.pek 21-Oct-2010 20:55 507 <br>[ ] xray.prm 21-Oct-2010 19:46 1.6K <br><br><br>I would expect to see the relation energy vs optimization step in the Discover.log file, but instead I see 'finished'.<br>Help me please<br><br>
Casper,
To get the energies at each step in your output file, you would need to add this line to your input file:
execute frequency = 1 command = {print output +energy_summary}
There are lots of other options for the output which you can find in the manual.
Best,
/Jason
Hi
From a Discover run you will never see a .xcd (or .xsd, or .xtd) file on the server. Discover writes out files in Formats that pre-date MatStudio. So for example Discover will write a .car (or.cor) & .msd file and they will be downloaded from the server to the client and imported into MatStudio as a .xsd. A .arc or .his file is seen on the client as a .xtd file, etc. As for the .xcd file; that is produced on the client from information written to the .pek file and then downloaded to the client at intermediate job update intervals.
Regards
Simon
Thanks Jason. Yes, I have found all the print options for the Discover outputs and trajectories in the manual. It works fine now.
