I am doing PhD ( mechanical engineering ) on impact analysis of Graphene reinforced polyurethane nanocomposite using Accelrys Material studio 7. For impact analysis constraint is very very important. Can anybody discuss various type of constraint used in material studio???when we used atom,length and lattice constraints??? During impact analysis is it possible to give velocity on the impactor or striker in material studio????
- Build Graphene starting from Graphite.
- Optimize a and b vector with the method you want to use, fix c and the angles.
- Build the Graphene superstructure you want to use.
- Add enough vacuum space to the model.
- Build and optimize the cluster you want to impact onto the Graphene layer.
- Add it at 6-7\AA on top of the Graphene onto which you want to fire it.
- Do a 1step MD with the method you want to use at the temperature you want to use. this is just to get the velocity property for the atoms.
- Download the results.
- Select the added atoms and edit the relative velocity of he added atoms and set it to a velocties that way that they fly towards the Graphene layer (typically, x,y=0 and z to a certain value).
- Do an NVE run with Current velocities.
The attached *.xsd file should be hopefully be ready to be used in an NVE run with velocities set to Current in Materials Studio 7.0.The trajectory of the complete run (Cl2 as the molecule to which the velocities wre assigned) is too large to be attached and was done with DFTB+ in Materials Studio 2017.
Although, this is not done with Forcite+ I think that this is an interesting starting point:
http://9pesxm.chemeng.ntua.gr/fullpapers/MP0256.pdf
With PU ans the possible ring spearing it might be a but more difficult to build the system using Amorphous Cell but let's see.
1. How to develop 0.1%,0.3% ,0.5% and 1% ( weight%) Graphene reinforced Polyurethane nanocomposite???Can I use amorphous module..construction option...density... 1.3 gm/c.c (nanocomposite experimental density value) ,Density of polyurethane 0.9 gm/c.c
2. How to develop Fe atoms hitting Graphene reinforced polyurethane nanocomposite???
If possible to send the you tube video of that tutorial in my email : animesh_talapatra@yahoo.co.in
At least in theory once you have the graphene model it can be used in an Amorphous Cell Confined Layer task.
By changing the number of graphene models in the build one can generate systems with different graphene concentrations and one needs at least 3 graphene models in the system I would say.
The problem I see is that we might suffer from ring spearings and that it might not be that easy to build the system.
The real problem is that with such low graphene concentrations the systems are simply too large to properly handle them and I doubt that this can be done in a reasonable amount of time.
The Cl2 system simply has to be replaced by a Fe atom if just an atom is needed
Composition
Molecule: The 3D atomistic document (
.xsd) containing a nonperiodic structure of a single molecule.Loading: The number of molecules per cell (for the Construction and Confined layer tasks).
Mole Ratio: The number of molecules of this component relative to the total number of molecules (for the Packing task).
Weight %: Read-only property reporting the weight
To which percentage does this refer:percentage of this component in the total composition.
By having a different number of graphene models (molecules) you can change the weight%.
The volume fraction can only be estimated. For what do you need it?
What will be answer if I want to mix 1% Graphene in polyurethane matrix???
segments, four urethane hard segments, four polyether soft segments, and four more urethane hard segments to represent realistic PU. The initial model is built by the amorphous construction at room temperature (298 K) with a density of 0.85𝑔m/𝑐.c (experiments 0.97 − 1.24 𝑔/𝑐c). The energy minimized using the Discover module in Materials Studio 7 in total time step 5,000 fs with a 1fs time step. NPT ensemble at 1 atmosphere and 298 K for 500,000 fs with a 0.1fs time step. Annealing is done 600K with a 25K increment (100,000 fs run with a 0.1 fs time step for each 25K) to cool down to room temperature. NVT ensemble is run for 100,000 fs with a 0.1 fs time step. Density obtained through the simulation was 0.95 gm/c.c. I have developed Polyurethane unit cell.Now how to develop various weight % graphene reinforced polyurethane nanocomposite.
At least in theory. I did not check if the current system size is sufficient to get the wanted weight% for the graphene model
Both papers use AIREBO as force field..
Please search on http://references.accelrys.com for AIREBO and check what was done in those papers.
If you need bond breaking the only option I see is to use GULP using the reactive forcefield (to see if your or AIREBO (I do not know if that force field can be used for your system) but in Materials Studio 7 things are somewhat limited here from what I remember.
As I do not know AIREBO and which potential functions are used I do not know if they are covered by GULP in Materials Studio 7.0
I tend to say that they are not in there.
I still think that your system may be to large for this.
Do you have GULP licensed?
