How to track the displacement of an atom as simulation progresses?
Hi All,
I have a simulation and I want to find the relative shift of an atom (in comparison to the starting position) as the simulation progresses. I was wondering if there is a method to either generate a plot or directly visualize (probably an arrow that shows the displacement with respect to starting position, & also showing the amount of displacement) in the Material Studio.
Thanks.
cheers,
Nitin
Answers 8
JD
JD 2011-02-25
Hi Nitin,
Although it is not really meant for it, you can use the mean squre displacement analysis in Forcite. Follow these steps:
  1. Select the atom you want to track
  2. Set "Origin step" to the number of frames in your trajectory (or some large number)
  3. Set "Length" to the number of frames in your trajectory
  4. Click "Analyze" and take the square root of the results in the study table.
Alternatively you could use a PositionAnchor and Distance Monitor like so:
my $doc = $Documents{"Argon.xtd"};
my $atom = $doc->AsymmetricUnit->Sets(0)->Atoms(0);
my $anchor = $doc->CreatePositionAnchor($atom->XYZ);
my $distance = $doc->CreateDistance([$atom, $anchor]);
$doc->Trajectory->CurrentFrame = 1;
for (my $i=1; $i<=$doc->Trajectory->NumFrames; $i++)
    $doc->Trajectory->CurrentFrame = $i;
    my $d = $distance->Distance;
    printf "Frame= %d, Distance= %f\n", $i, $d;
Best,
/Jason
NK
NK 2011-03-03
Thanks for you reply Jason.
I tried running the perl script, but i get the following error:
The index value 1 is out of range (function/property "Sets")  at -e line 7.
The line 7 refers to line 2 in your reply above. I also wanted to know what does 0 mean in this line? Also, what does "AsymmetricUnit" refer to?
These questions could be lame, but I am new to scripting in MS.
Thanks.
best,
nitin
JD
JD 2011-03-04
Nitin,
You have to create a Set for the atom you want to track. Then run the script. AsymmetricUnit is explained in the Help and is necessary if you have a periodic system. It filters out periodic images.
/Jason
ST
ST 2011-03-04
There is already a script on the Community to look at diffusive pathways for atoms and molecules. This might be of use to you.
Cheers
Stephen
RA
RA 2015-05-08
Hi Nitin,
Building on from Jason and Stephen, you could visualize the pathway by a chain of distance monitors connected by anchors, like so (click to animate)
I attach the script that I used with the example trajectory of a molecule in a zeolite.
Reinier
comment imagecomment imagecomment imagecomment imagecomment imagecomment image
BZ
BZ 2016-03-13
Hi Reinier
The script in attachment was very usefull for me.
But I tried to modify it for my project.
I want to track displacements of a set which is assigned to an atom.
#!perl
use strict;
use MaterialsScript qw(:all);
my $xtd = $Documents{"Project.xtd"};
my $trj = $xtd->Trajectory;
my $xsd = Documents->New($xtd->Name.".xsd");
my $atoms = $xtd->UnitCell->Sets ("atom-1");
foreach my $atom (@$atoms)
    print $atom->Name ."\n";
    my $color = RGB(int(rand()*256), int(rand()*256), int(rand()*256));
    my $anchor1;
    for (my $i=0; $i<$trj->NumFrames; $i++)
        $trj->CurrentFrame = $i+1;  # Note +1 as frames indexed from 1
        my $anchor2 = $xsd->CreatePositionAnchor($atom->Center);
        $anchor2->Style = "Dot";
        $anchor2->Color = $color;
        if($anchor1)
            my $distance = $xsd->CreateDistance([$anchor1,$anchor2]);
            $distance->IsLabeledMeasurement = "No";
            $distance->Color = $color;
        $anchor1 = $anchor2;
But the script are not successfully completed and it has an error:
There is no function or property named "Center" on type "Object" at -e line 19.
I know it is for centroid of molecule. But I have no idea to fix this problem. Can you help me?
Thanks in advance
Behnam
RA
RA 2016-03-14
Hi Benham,
To get the position of an atom, use XYZ rather than Center, i.e.
my $anchor2 = $xsd->CreatePositionAnchor($atom->XYZ);
Another problem might be that
has the effect of looping over the set content, which might include objects that aren’t atoms (e.g. bonds). It would be better to filter for atoms first,
my $atoms = $xtd->UnitCell->Sets ("atom-1")->Atoms;
If the atom has a unique name you could also directly filter UnitCell without using a set.
Regards,
Reinier
BZ
BZ 2016-03-14
Hi Reinier
Thanks a lot. I applied your suggested corrections. It is workig very well.
Best
Behnam
