Now I can get the morphologies of microphase by the DPD modul, but I can't construct the relation between the the morphologies of microphase and mechanical properties for the coblock polymers. Because we know that DPD method is only suit to the liquid, not the solid. How can I carry out this idea based on the Materials Studio?
Hi, there are a few things you can do to investigate the mechanical properties of your system.
First you can subject the system to an external strain, and see how the stress relaxes in time from such a perturbation. At short time scale a system will respond elastically, but then the molecules will flow, dissipating the energy you put in. A fluid will eventually dissipate all energy this way, whilst a solid or network is capable of storing some elastic energy, leading to a stress increase. Such an increase divided by the strain will tell you the modulus of the system. There is a script on this forum that does something like this: https://community.accelrys.com/message/2072
Second, Accelrys distributes a product called MesoProp (http://accelrys.com/products/datasheets/mesoprop.pdf) which allows you to predict the mechanical properties of composite morphologies, based on continuum mechanics. You specify the elastic moduli of all components in the system and read in the density fields, as they come out of DPD. The program will perform a finite element calculation predicting the elastic modulus of the composite. In the same way this program can predict thermal expansion coefficients, thermal/electrical conductivity, permeability and so on.
Hope this helps,
Reinier
Hi Reinier,
At resent, I have tested the first method you provided (subject the system to an external strain, and see how the stress relaxes in time from such a perturbation). However, we can not find the dependence of the stress on the morphologies (such as sphere, cylinder, lameller, etc). We think that this is the shrotcoming of the soft potential, so we prepare do it as follow: firstly, we use DPD modul to obtain the different morphologies from the microphase separation. Secondly, we still use your first method and subject the system to an external strain, and see how the stress relaxes in time from such a perturbation, but we want to change the soft potential by the L-J potential or the Morse potential. Do you think this idea? How can we use the Mesocite modul to finish the object?
As your provided second method (by the MesoProp modul), we regret that we can not buy it, because it isn't supplied in China.
Best,
ZhouYang
Dear ZhouYang,
There should be no problem supplying the MesoProp product; please fill in the contact form on the corporate web page
http://accelrys.com/about/contact/index.php
and our distributor in China will get in touch with you.
I will comment on the scientific query separately.
Best wishes,
Reinier
Hi ZhouYang,
I fear that the system will not be able to equilibrate by just replacing a soft-core by a hard-core potential, so I am not sure this method will work.
To proceed I suggest to first verify that the different phases have distinct elastic properties; otherwise you will not be able to contrast, whichever morphology. For example, you could simulate the strain experiment with the pure components.
I imagine results will depend on the length of the polymer, since the bonds are capable of storing elastic energy. You may want to experiment with the stretch modulus, and possibly the bending modulus, and investigate the effect on the stress relaxation in your strain simulation.
In the 5.5 release of Materials Studio, it is possible to subject the system to shear deformation. This may be useful to investigate the shear modulus and/or viscosity of your system, to further characterize the mechanical properties.
Reinier
