How to set Z-aixs direction as Orientation Reference in Orientation Reference
Hello,actually, I can't find how to set a specified direction in this SOCF. It seems that there is no option for setting the direction in the two "set" commands. I've checked the help documentation and script statements but couldn't find any relevant information. I hope someone can guide me on how to set (0, 0, 1) as the specified direction for the collection of model bond vectors. Thank you, everyone
Answers 3
CM
CM 2024-01-03
SOFC is Solid Oxide Fuel Cell?
What does this mean:
Do you want to set the orientation of a cell that way that z is along the c axis?
XH
XH 2024-01-04
SOFC is Spatial orientation correlation function, I want to set Z-aixs as the direction
FH
FH 2024-01-05
Hi, you essentially need one distance monitor that is always in the z-direction and you need to turn that into a set. Assuming that one of your lattice vectors is in the z-direction, you can "measure" the distance between an atom or bead and it's periodic copy in that direction. This distance vector will ALWAYS be parallel to the z-axis. Create the distance monitor, turn into a set and use as set B. Set A will then be determined by your actual system.
Maybe there are other ways of doing this, I'd be interested to see what other people say.
