how to select atoms in ZSM-5 supercell in Circular shape ?
Can someone help me in selecting and removing atoms in ZSM-5 supercell in Circular shape.
To make my question more clear I am attaching a journal article(second page, simulation details [subtopic]), where they removed atoms in ZSM-5 supercell in Material studio.
I tried my best to select atoms in ZSM-5 framework but I could make only square or rectangular selection and deletion of atoms.
Please help me.
Thanks in advance
Regards,
--srikanth bojja
Answers 4
HP
HP 2010-08-17
Hi Stephen,
I could successfully select and delete atom of ZSM-5 supercell in circular shape with your help.
Now I am stuck with another problem.
Because of removing atoms in circular shape from ZSM-5, some silicon and oxygen atoms lost bonds and now I want add Oxygens to bare silica atoms and Hydrogen to bare oxygen atoms.
I tried my best and could update only hydrogen ( problem is it updates hydrogen on every bare atom)
I am attaching my ZSM5's .xsd file
help me
regards,
--Srikanth Bojja
comment imagecomment image
ST
ST 2010-08-17
Hi Srikanth,
You can do radial atom selection by using the Atom Selection tools. Select Edit | Atom Selection from the menubar. Change Select by Property to Radial Distance.
You have the option to specify the radial distance, and whether you want it relative to selected atoms or to an arbitrary location.
BTW, I have also removed your attachment from the post. In the future, please do not post copyrighted material into the Community.
Cheers,
Stephen
HP
HP 2010-08-17
Thank you verymuch ...
It helped me a lot..
i attached that journal article only for reference/ to make my question clear
anyways thankyou very very nuch
cheers
--srikanth bojja
ST
ST 2010-08-18
Hi Srikanth,
There is not a simple way to do this automatically. You will either have to go in manually and do this or, if you can create a rule, write a bit of MaterialsScript to do this.
You can use properties such as AttachedAtoms or Bonds to work out how many atoms are attached to the Si and then use functions like CreateAtom and CreateBond to adjust the structure.
Cheers
Stephen
