Hi MS users,
I am trying to predicte the heat of formation using Dmol3 (i.e H2O) but I got this message in the outmol.txt file:
"DFT atomic data not found.
No matching atomic binding energies in Thermo_Atom file
Skipping heat of formation calculation."
Any idea how to get calculated by Dmol3?
Thanks,
Ahmed
When we set up the DMol3 heat of formation calculations, they required some empirical corrections for the atomic calculations. We computed this for a bunch of different functionals, basis sets, grids, and so on. If there are data in that file that match your input settings, tnen it will compute the heat of formation. This is not a very general way of doing it.
I recommend instead that you compute heat for formation by computing reaction energies.
2 H2 + O2 -> 2 H2O
The heat of formation of H2 and O2 are both zero at 1 atmosphere and 298K, so the reaction energy is the heat for formation of 2 moles of H2O.
You can do similar reactions for more complicated molecules.
Hi George,
Thanks for the clarification however I’ve tried to calculate the Gibbs free energy for the water by following the tutorial “Calculating the free energies of chemical reactions” I got far results (-47961.8 kcal/mole) from the actual reported data (-56.69 kcal/mol), any clue?
Thanks
Ahmed
I'd need to see your numbers to understand what went wrong. I'd guess, though, that you picked up a total energy for some components and binding energy for others. Or you have inconsistent settings, i.e., different basis sets & functionals for reactants and products. What are the energies and Free energy contributions that you obtained?
Hi George,
Sorry for the delay in replay as I was out of town recently, here is the steps and the settings I took during the calculations:
1. H2O
2. O2
3. H2
The smearing value for the all calculation was 0.005 Ha. with DND basis set (3.5)..
Thanks a lot,
Ahmed
you are using a different DFT-D correction for O2 than for H2 and H2O.
Better that you don't use any DFT-D at all for this, but if you insist on using DFT-D then make sure they are all the same
Thanks George... problem solved
Cheers!
Ahmed
I would rather add to this thread than begin another for a very similar topic.
If I were calculating the heat of formation of a hydrocarbon, CH4 for instance, what would I model as the carbon reactant? Theoretically the heat of formation would be dHf(CH4) - 2.dHf(H2) - dHf(C) ... where the C is graphite. But how does one perform a geometric optimization on a graphite crystal to obtain the thermodynamic values for comparison?
Thanks!
Aha! Figured it out. Import the graphite model from the MS library (file - import - structures - ceramics), convert it to P1 symmetry (build - symmetry - make P1) and run the normal dmol3 geometry optimization and frequency analysis to get the energies required.
Note that the values obtained are for five carbon atoms ... so, for instance, if I were making a single methane molecule, I would use 1/5 of the energy from the above calculation.
Enjoy!
