Dear All,
I have a solid-liquid-solid sandwich-like system, liquid solution contains ions. For some ions, I want to keep them within certain distance from one solid phase, does anyone have idea how to do that? Thank you!
Regards,
Jingjing
Regards,
Jingjing
Regards,
Jingjing
Forcite supports atom-position and atom-atom distance constraints. I think the application you have I mind requires constraining either individual directions (i.e. X, Y, or Z), or atom-plane distances, neither of which is supported (though it is possible to create atom-plane distance measurements).
Perhaps you could elaborate on what you want to use such a simulation for so we could see if there is a way round.
Best,
Reinier
Thanks for your reply. What I'm working on is a solid-liquid-solid system, I have two different surfaces in contact with the solution containing two aqueous ions. I want to study the adsorption of the ions on the two different surfaces. The distance between the two surfaces is 50 angstroms. The simulation time is around 20ns.
I had two problems now. First, after 16ns of simulation, co-ion adsorption occurred on one surface (the one I'm interested in) , however, I only want to study the interaction between the surface and one type of ion, and keep the other type of ion away from this surface. The other problem is that although according to literature, 50 angstrom is big enough to avoid the interaction between two surfaces. Because some ions on one of the surface (the one I'm not interested in) are inter-column ions, they have weak interaction with the main column structure of the solid phase, these inter-column ions diffused out of the solid phase, and they came very close to the other surface which I want to study.
To sum up, I had two problems which made the adsorption on the surface complicated, first is the co-ion driven adsorption, the other one is that the ions from the other surface might also affect the adsorption.
That's why I want to use restrain to keep some aqueous ions away from the surface I want to study. I tried to group one of the solid phase as motion group to avoid the inter-column ions diffusing out of the solid phase, I'm still testing this.
Do you have any suggestions? Thank you very much!
In principle you could replace the co-ion in the liquid by a neutralizing background (jellium), by simply deleting it and using Ewald summation (which will automatically add such a background). However it might be better to keep it and, if necessary, fix its position or restrain it to an anchor.
Good luck!
Reinier
Thanks for your suggestions. I double checked the charge of solid phases, each phase has the total charge equal to zero. I tend to fix the solid one of the solid phase to avoid ions leaking out.
For the co-ion liquid phase, I tend to restrain one type of the free ions I'm not interested (I name them ion 2) in to a surface. So if I want to keep them away from surface 1, can I add a best fit plane to surface 1 -> add distance measurements between the plane and ion 2 -> set restrain by adding minimum distance between surface 1 and ion 2?
Actually, I tried to avoid surface ion leaking out by building a fixed liquid phase - mobile liquid phase - solid phase system, so that I can only study the interaction between surface 1 and the ion 1 which I'm interested in. The fixed liquid phase has same concentration with mobile liquid phase, I read this method in a literature. The MD simulation when well until about 10ns, then the solid phase became a little a bit disordered compare to solid-liquid-solid system. Why this happened? If I fix one of the solid phase as you suggested, will I have the same issue?
Thank you!
